Wheel and plastic arch trim off, it's accessible from thereBrought a new window washer pump as the old one was leaking fast and now have to figure out how to get to it! I'm sure I'll have to take half the car apart to get to it.
Hi, where did you get a boot struts from? Did you buy an adjustable force or fixed force? I'm looking for a pair. Find GS10-22 350-400mm 800Nm from NitroLift but I think 800Nm it isn't enough. Thanks for any info.Just upgraded my rear boot struts to accommodate a fixed bike rack ... 10 minute job with a spare pair of hands to hold the door open. Went 930Nm which works a treat
Thank you.SGS engineering supply them. 850N is optimal.
Thank you.Don't forget the Ball Sockets,
Is 850N enough to hang a few 7mm wet wetsuits? Or should I go for more?SGS engineering supply them. 850N is optimal.
Double din back out this morning...steering wheel controls jack had come out. Now back in and working fully. Took the chance to properly earth it and now back in and much better fit this time; more flush to the dashAlso took the oil filler cap off to check all good there....only went and dropped the thing in the engine bay
- Fit double din head unit incl DAB aerial and mic
- Fit dashcam
All good though....after 15 minutes of panic and despair I retrieved it from one of the undertrays
Thanks to those who helped to advise me on what I needed adaptor wise for the double din. Only minor gripe is the steering wheel control cable must have come out when I was shoving the unit in...was working 100% when I tested it before that. No doubt one day soon I'll be pulling the head unit out to check. Job for another day now though. Feeling quietly satisfied with getting this done myself, being a total novice.
Someone on here has a Surf Bus, can't remember who though and hangs wetsuits off the rear lid not sure the NM's of his struts though.Thank you.
Does that DPD van have a paint delivery by chance?today i fitted the inner side panel i broke and took my front lip off ready for a tidy up and the rest of the day tinkerinView attachment 52128g with nippers mx1 golf
850N is just for the door to raise without it stopping en route. Once it is up I couldn't say how much weight it will hold.Thank you.
Had some free time today so fitted my SGS boot struts. Read lots of people recommending 800N for standard or 850N if using a bike rack etc. I played it safe and ordered 820N as I will need to hang items from it time to time. Also bought the standard ball joint for one end and the extended version for the other side.
Comparison Old Vs New:
Results are night and day. Really happy with the extra lift and that it sits in line with the roof when open. Opening and closing is just as easy before but now I won't bump my head
Haven't tested it yet but feels strong enough to hold a few wet wetsuits with out giving way which is exactly what I wanted
Any helpThank you.
Sounds shady to me Bobno its been parked outside for 4 days he lives across the road spends more time there than doing deliveries
The ball sockets, do I need 2 or 4?Don't forget the Ball Sockets,
