Put a new battery in the remote fob.. that’s if for a while ..
Is there a brake pad that is less dustyWhat about the yellow brakes?
Waiting for the paint to be delivered ... bye bye goldWhat about the yellow brakes?
The Brembos on mine aren't too bad but dust means stopping power.Is there a brake pad that is less dusty
Its the brembos ivvgot on mine now I dint no if the red yellow or green pads were any less dusty as I could spend all weekend cleaning the crevices out on mineThe Brembos on mine aren't too bad but dust means stopping power.
Wonder if Hawk make ones to fit an Elgrand, I have them on my Subaru, pretty good pads and low on dust.The Brembos on mine aren't too bad but dust means stopping power.
Can't check without a part number as they don't list the ElgrandWonder if Hawk make ones to fit an Elgrand, I have them on my Subaru, pretty good pads and low on dust.
Homepage
www.hawkperformance.com
Have you checked your rear shocks outReplaced osf brake flex hose, this proved a bit of a chore, coaxing separation of the rigid line from the flexi without damage, then bled brakes. While in the front wheel area replaced drop links with adjustable ones. Set to the length of standard links for now, and once i've time to fit the poly arb bushes will try a tweak up and down.
Body roll was massively reduced when i fitted the air bag assisters a few years ago, but there may be room for some fine tuning ?
Robertn
So you checked your nuts and gave them a squeeze........Gave her a quick wash, thought it would be wise to run a torque wrench around wheels (had new tyres fitted a few weeks ago) found 3 nuts not up to torque. Placed my first little order with @BMR looking forward to seeing his packing for myself.
That's right, I did that after a quick run down.So you checked your nuts and gave them a squeeze........
Just thought I'd check dint know mibecwas that bad till I swapped themHi Kenzie, no sogginess, rear end settles straight away, just the occasional flutter as the rear drifts out a touch, maybe a little too much throttle on exiting the bends.
Robertn
You'll notice the difference when shutting the lid, its like a mini work out.Added gas struts (900n) from SGS. The difference in opening height is amazing. Not tested it with my bike rack on yet though.
Really impressed with the customer service from SGS and for £66 delivered would highly recommend.
Also tested my fuel lagoon thermal window covers. I’ll do anything to avoid watching ManU at the moment!!
