Yes definitely the bestDenso Iridium TT Spark Plug IKH16TT are quite popular, I've put them in mine.
Correct mateChecked all exterior bulbs.
Just to confirm, the lower light cluster is brake light, reverse and indicators.
Mid level bar is rear red lights and only has one brightness for when side lights and main beam is on?
apparently a piston has broken up and damaged bottom end significantly....so im told lolWhat was the diagnosis on the knackered engine @E51ZRider
Jeez. At least you’ve managed to source an engine mateapparently a piston has broken up and damaged bottom end significantly....so im told lol
Do you have a link to this as its cheaper than the ones I can find,View attachment 44709
Just bought one of these so will have 2 usb and cig lighter socket available. Will fit dash cam to cig lighter (maybe hardwire to fuse box later), usb for phone charger and other usb for dab.
Yeah sausage fingers, edited.......Nothing worse than when you have a witch for a passenger.
Item number: 143844957263Do you have a link to this as its cheaper than the ones I can find,
I usually wire in a 12 to 5v unit with twin head USB's to power a dash cam and phone as I hate cables in the cabin.
What sort of speakers, does a standard 4" fit? I never got round to trying.I have them but also the tailgate speakers, should be fun.........
Where abouts would they go though? Guessing you'd have to really pack them out with sound/vibration absorbing material or they'd sound terrible.What sort of speakers, does a standard 4" fit? I never got round to trying.
Below the rear screen either side to the tailgate. They are 4" on the diagonal and I think they have a low profile but I haven't checked.Where abouts would they go though? Guessing you'd have to really pack them out with sound/vibration absorbing material or they'd sound terrible.
Nice! Curtain twinsBelow the rear screen either side to the tailgate. They are 4" on the diagonal and I think they have a low profile but I haven't checked.
Out of interest which bits of trim did you remove and how as I don't want to break any retaining clips, one light is in the cable passed through to the other side as I want to go down the drivers side and power the lights from the original boot light but am stuck, photo of trim I want to remove but I don't want to just hack at it.Yeah, real easy to fit and wire in. I only took 2 bits of trim off (centre top piece around 3rd brake light and the section that runs down from that to the main tailgate cover, rest can be done via the blanks you remove.
Makes a massive difference, I usually end up faffing about with head torches in the winter!
Will be once I get them to slide properly.......Nice! Curtain twins
