- HAMPSHIRE
- robert
- South East
it all in the eyes ![Mask :mask: :mask:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I bet he was smiling; I find JDM-love is pretty universal and very inclusiveJust put £20 petrol in the cube from empty over half a tank now.. black step wagon owner was smirking at the cube,,, if he only knew daisey .....will keep an eye out for him when I’m next out in her , see if he has the same smirk ...but he could had been smiling as he had a mask on...
Probably because at the back of your mind you know that if you do get it regassed all the gas will soon leak out of a hole in corroded rear AC pipe :-(Why the fuck didn’t I get daiseys air con re gassed knowing a heat wave was on its way.. on the plus side the wife’s cube is ice cold ..daisey has rusty brake discs ... first time ever in four years
I Think my rear pipes are not too bad... Adrian gave them a good covering with underseal ... only one way to find out I’m guessing ..Probably because at the back of your mind you know that if you do get it regassed all the gas will soon leak out of a hole in corroded rear AC pipe :-(
Mine had a good test today. Sat idling for a while with aircon on, the electric fan kicked into high speed mode and all remained cool inside, temp gauge in normal position.
Kinda pisses me off that the wife air con works great and mine don’t, and only takes a minute to cool the cube down ... plus side saving a fortune in petrol .. 40+ mpg
Too hot to get in daisey at the mo.. lemony is ice cold before I get out of the close .. hopefully will be a bit cooler tomorrow so will have a check but she has been blowing warm for a few years now .. one of those I get around that jobs and you never do...That's probably more to with the amount of air inside the Cube it has to cool down, probably a quarter of the size of the Elgrand![]()
Plus, check the rear aircon settings on Daisey, checked mine the other day on the way back from the coast, the rear AC was set at 24, so lowered it to 18 and now it's a lot faster at cooling it all down![]()
