It’s all quite easy. You just need to take your time and go slow so you don’t damage all the plastic clips.
First remove the two small covers that hide the screws on the tailgate panel and remove screws
View attachment 12895The panel wil then pull down but be careful as you don’t want to crack it.
Pop off the covers where the lights go.
Pop off the plastic cover around the window. Side and top. There is a screw in the top behind a cover.
Remove seat belt bolt
Pop off the trims in the car just enough to give access to get your hand in to feed cable
Pop off the large access panel below the boot light
The kit has two cables. Take the T shaped one and feed it across the talegate and drop the ends through the holes for the lights
Connect lights and clip them into the tailgate panel. I had to trim a small amount of plastic off the panel for the clips because they were in slightly different places to the original covers
Get the second cable
Cut off the large white connector block. Remember to leave yourself enough wire to reconnect it.
Now the hard bit. Thread the cable through the rubber tube between the boot frame and tailgate. I did it by stripping off the black insulation. I then pushed a length of welding wire through the tube. Tape the wires to it and pull them back through
Feed the cables down the boot trims to the existing boot light.
Pop out the boot light
Make the connections to the cables off the existing light
Re connect the white connector you cut off and plug into the one on the T cable.
It should all now work.
It’s then just a matter of putting everything back.
It took me about two hours to do.
