LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
But what about.......?
Is this legal?
Why does this need doing?
Can't agree more.
Does E52 have the Cat problem as well?
I've been quoted £500 for front cat de-core. Happy to travel I'm in Bedfordshire, anyone had this done and happy with results for less? E51 s2 or s3 not sure at all. Dont want eml on and would like someone who's done it before. Any suggestions?
I guess you have LPG fitted otherwise you may have some problems with emissions.
I had my fronts de cored about 4 or so years ago cost me £400 ish, they did drop the engine and subframe though . I think there are easier ways of doing them now. Got LPG no cats and no problems either with MOT or fault codes . Got it done by Steve Mennell at tojomotors.
So I think I may have the dreaded front cat failure.
Rears are decoded. Was driving today and had the distinct rattle from the front when accelerating at around 1800rpm. Other than that was driving fine and no loss of power, only rattled around that rpm when accelerating.
Just before getting home I had a check engine light come on (was still driving fine and no loss of power).
Checked the code and it's P0174 (lean on bank 2). I'm assuming the drivers side cat is partially blocked and affecting the sensor/fuel mixture?
It was still driving fine. Have it on the driveway and will pull out the front cats to check them out and decore before driving again.
Hi. As a newbie, reading this thread has been very educational and very worrying. It appears that de-coring is the the obvious approach, so I decided to look under the car for rear cats and see if they are within easy reach for me to work on
What I found is shown on the photo below. It appears that both rear cats are missing, replaced with the bit of straight pipe. Is that so? Am I looking in the right place?
The car has just passed MOT (before I bought it), but now I am quite concerned about the next MOT.
In any case, looks like cat failure might now be lesser of the concern :grinning:
vhtIVAHCESNtc9P_PPKcC8gvWpVsfzHraCiqNQ1I0d4xnxYM9SDzt5b-WEaX7RfkkCGbQ6_yleXKKVfZTrxUz0nuMu2JLhqFd4y4_YNZbjMGvz6VATwFdC1OpIjF2Y39F4qRhcbZjrDEae8j4x_hyNSco62A0x8LbJaIAEQWKHLZMLMxOtNPA0gAd_g2cMGwuh8jVflf5H8UNzMqM48WT547qinSd6s_aVZJcozdruEPFWcZbjSHvR2E-AsC0Bq_VovOq1N9Jo-Lkoy8JiYKKD3Kmn2ffHBg1_Pno1Mve2XTruny2he_vKlrpXcA4aS8QTmt39mAZlm-CSJay9_he4wi4vPKmO4IMVAxc6C73dt1awoL-0dfbINVy8Fc2xbiaf3Px0Ro6zntj5XY0bh5YhivuAjgHIOpZ1bX-ZUSUZU9YEHHQKOnbhqAyKQ-bRzW93RXg0RcyG7g7T72AHuu6vORYIp2dJ8XHGe3R3ZH4pU7U0PE4gt3sbQzkPkGeBK0-4sd2q2TtNEEAo4M2jnCd6XC-3cnOjpr6sr5SQeUMXfKPCEE5YXRdhXojIHqX_x9NTSMAjp7w0myyeL44eF-Hbyqoe3kTeJdKWLjg0mYh0BRHcMUvebJnxaqNEojOqX6-wfmYRq838dInbVRrHBwwdxlkh3a47TUJVqQeCPBjkWV9UinX8Z-WcbJ6F2eDTRPQHBsQnnpRhxbhG6xiBsgrG1Sv3Z34ggQ6ZHvSXN4WEqdifdDho5fnGWD7FX74PPcazskeY1Q1YBHKqcKirGUrs0DUrjUkiqDZj4VoP9i-L2r2fL9C_HFvjtCdZG6zMLcq3lDTSP5QutaRJxLVsasBdn945KqoXIDh-wR_garmbrLkbcAh1y9o5bby9MrpmtpZBVFEubRluFvcWF2DkPVXTsyLLbUX1iqlhlzMikyHbSUg1AqfiHalsZ6YD7NF8EyNAXp49xo9uk0lu6wIg4XYQ=w2658-h1416-s-no
Yep, that’s a de cat pipe, should be same on the other side but will be a longer pipe
Those are the rear cat replacement pipes. Will pass MOT no problem. The front cats are the big issue.
So I've had a fun long weekend of pulling off front cats :)
The drivers side with the rattle was surprisingly still pretty intact at the front. I'm hoping it's only just started to break up.
Got a lot out of both sides (picture below has the drivers side in the plastic tub, passenger side in the box)
Frustratingly I managed to mangle the O2 sensor thread on one cat, so waiting to get it tapped and a new O2 sensor before the drivers side goes back on.
Judging by the amount of cat crap that came out the drivers side, I'm hoping it only just started to break down and I got to it in time.
AUSTRALIA:
For anyone from Australia, I just got my rear cats removed and replaced with test bypass pipes. Can't tell you the relief of having these removed and giving the car a proper rev for the first time.
It was $550 for the two bypass pipes, done day of drop off. Stoked.
AUSTRALIA:
I'd probably do that also at some point, but will wait till the extended warranty finishes in 5 years' time.
This thread is not only useful to all E51 owners but also to anyone looking to buy one of these magnificent vehicles. Thanks EC owners club, and thanks to ALL of you for taking the time to post your 'de-coring' stories. Really useful. Thanks again
Wow that was a lively debate wasn't it? As a newbie who has not yet taken delivery of my Elgrand and also being a mechanical and electronic mental pygmy, I started reading the debate and immediately thought that those Japs must be really cunning bastards to dream up a sales pitch where every Elgrand comes with 4 yes 4 cute little moggies. I have now been educated and understand why they are called cats - who wants to have to say catalytic converters every time you refer to them - especially if you are having the conversation in your local pub!! Another "Eureka" moment was when I discovered that the bad eggy smell I have experienced in my other cars was not down to the dog or the wife after all!! Its all very enlightening!
