Hello all,
Still waiting for my Elgrand E51 delivery, but have already a question - can anybody relate to the size of the cats? I was thinking of Euro4 200cell metal cat replacement in front + de-core / pipe in rear, but cant find any size on part list or forum. Any product that can be suggested or referred as an example?
Hello all,
There was another here by @Wolop I think who made his own system.
do you have in Finland a company called powerflow exhausts (i think they are world wide) if so they made and fitted my front cat replacement no rear cats and full exhaust system from stainless steel for £1250 (£490 was labour) they used two generic 400 full metal cell cats and copied the rest of the system if you make your own then its your budget/imagination that is the limit
That i seen, but i am in Finalnd (customs will be huge) + i had requested a quote already some time ago - no answer + that post really do not provide dimensions on the cats itselfes or brand / model. I have a welder to do the job here but i will have to supply parts myself.
@Elementian said he'd taken some time away from the forum in a recent post, maybe worth reaching out again.
I got elemetian primary cats and decat pipes really nicely made with a very comprehensive fitting kit can highly recommend 😎
Ah right. I saw those noise valves and assumed it was something you had done.
Hello all,
My suggestion would be to not decore any of the cats and just get a either elemetian primarys and decats / or just get a full custom exhaust made straight away, with metallic cats if you have a local company.
I sold my original primary cats for £280 if there were 4 (already decored by vineplace) that would have been £560 towards the expense of the full replacement.
Aha yes i have those but after doing them i wouldn't recommend them, it was an itch that needed scratching and im not happy with them...... yet
Hello,
Thank you very much for all your answers - i will squeeze the knownledge of them. However none of above answer my original question - what is the ori cats size.
ah sorry maybe winchester could answer that he does them all the time
I can see from one product specification the following:
Dimensions:
Diameter: 60mm
Length: 260-268mm
Width/Height: 122mm
I just wonder if that will physically fit there, or too big. This is only the cat size, i assume a little can be played on the pipe itself, but not much.
Could I have some advice please in regards to this. I checked the Nissan website and found this. I am still unclear as to any action I may need to take?
https://www.Nissan.co.jp/RECALL/IMAGES/pix.gif
recall notification number3225recall start dateSeptember 13, 2013
The structure, equipment or performance situation and its cause that are found to be in a non-conforming stateDue to improper programming of the engine control computer, the amount of air taken into the engine may be insufficient when the engine is decelerating from high revs and the accelerator is off. Combustion with a catalyst causes the inside of the catalyst to become hot, and the catalyst may be damaged. For this reason, fragments of the damaged catalyst generate abnormal noise, and if the rear catalyst is clogged, acceleration will be poor, and in the worst case, the engine may stall after the engine malfunctions.
Details of improvementAlong with modifying the engine control program to countermeasure specifications, inspect the damaged state of the catalyst, and replace the catalyst (4 pieces) with a new one if there is an abnormality.
Check your rear cats have been emptied bud, theres so much info on this forum.
I don't want to leave things to chance with my Elgrand and reading the advice at the start of this thread am going to go with Option 3. - 'a custom made stainless exhaust'.
Sugoi in Southampton recommended a bolt-on kit - but I wasn't sure what they meant by this?
Two questions:
1. Can anyone recommend a relatively cheap place to get the replacement stainless steel exhaust work done? ( I've looked online at Proflow who seem good value - anyone use them?)
2. Do I have to report this to the insurance company as a modification?
There is a lot of info on here but confusing for a newbie!
Thanks for any replies.
ok i got mine done by powerflow full stainless thats front cats no rear cats silencer back box and tail end of your choice £1250 with vat this is with £450 labour it passed mot emissions with flying colours and no you wont have to inform the insurance as it is a replacement of a throw away part
Ok thanks for the info.
Your right Alan exchange item w
Your right Alan postal exchange probably won't work economically but over the coming months as we have time we are setting up drive in exchange cats along with exchange reconditioned front wishbones and brake calipiers.
This sounds right up my street Steve. I think I’m going to get over to you over the winter months to have all the bushes done (exchange wishbones or however you do it) and also potentially all wheel bearings. I want a SS exhaust too at some point I don’t know if you can help with that?
Stuart.
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
But what about.......?
Is this legal?
Why does this need doing?
Very much appreciate this detailed guide to this important issue!
