Well today I did a xmas rubbish tip run in mine at 07.30am to the local dump site. I know now exactly why I went and bought another Elgrand. Once those 2 rear seats are folded away its got plenty of room for what I need to do and I filled it up to the roof with all the crap ( neatly bagged up of course ) I could find and off I trotted.
Had a nice drive around Swindon hearing my new sporty zorst note all the way. Dropped in to Asda and bought a new set of those flat blade windscreen wipers for her ( 3 in all ) and will change them tomorrow I think now as the outside temp has dropped off again.
Topped up my fuel tank again to the brim ( £10 ) and re-set the fuel computer. She started off @ 15.6 kpl and settled at 9.8kpl but I was just cruising around town and with my zorst box mod now completed I expect this will increase on the motorway to above 10 kpl hopefully. Still got to arrange to get my Cruise kit fitted and the guy can fit my Next base Duo dash cam hard wire kit at same time or I might just check my handbook for a SPARE 12v source in the fuze box and plug it in there. Its good that you get BOTH leads too for differing size fuse sockets.
Cheers
Well I decided to go outside and fit my new wiper blades from Asda and my Nextbase duo dashcam.
All did not go to plan!!! The wipers are Crap so they will be going back. I also found out that the E51's rear wiper is a specific type fitment too so that wound me up and then once I had fitted the 2 x front wipers the passenger one was missing the screen so I put my old ones back on which have new blades in them BTW and I will take the others back to Asda for a refund.
I put a set of them on my brother in laws E50 the other week and they worked fine albeit the fittings are slightly different and standard type. Never mind eh. LOL.
Onto the Next base Duo dash cam next and I had one of those hard wire kits with the 2 x differing fuse carrier lines which was great as the Elgrand has those bleeding mini fuzes.
I consulted my new English workshop manual in the Electrics section ( fuse box area ) and quickly saw there were about 4 ports empty and possibly spares to fit add on devices maybe??
Anyway after a lot of messing around I simply could not get the lead to power up. It was either a bad earth or just me. Are these spare mini fuse ports in the fuze box behind the drivers side knee coin box LIVE????? or NOT???
In the end I admitted defeat and neatly installed the power socket lead instead and plugged it in that way and all worked fine. Only issue now is that my 12v port above the cup holder tray is now taken up and ive had to move my little volt metre jobby in to the rear 12v socket in the RHS of the boot area where I cannot see it!!!! Doh. LOL.
These things are indeed set to test us. LOL
Richard Fox
Double Elgrand Obession!
Best wipers these Bosch AeroTwins!
Cannot believe how super silky and quiet they are! Well worth investing in a pair if anyone are needing a new set of wipers!
AR16U and AR26 is the model number, although I saw @Arctic Fox has got a 17 inch? Mine already originally had a 16" so I thought this was the correct size :(
@Brendan1969 you need these buddy, silky smooth and I believe the rear is from a company called Denso.
Richard, ive just looked on ebay and got a pair of Bosch Aero twins up. AR26U & AR16U ( as a pair ) for £18.50 or a pair of AR26U & AR15U for £20.50.
As I understood it the passenger left wiper on mine is 15 inch long so I am wondering if a AR16U will be too long and foul the edge of the screen pillar???
Could you clarify for me please what you have and if its a AR16U does it clear 100% and no fouling/touching of the screen pillar??
My dealer ( WRM ) did say they had replaced the blade inners ONLY and not the actual blade arm itself so I am guessing it came from Japan with a 15 inch fitted.
Cheers in advance
48 yrs old 30 yrs driving 9 yrs ncb and 0 points
Something not right there my friend. With those credentials they should be giving you cover for FREE.
Do you live in a high crime rate area???
I have an Admiral multi car policy and I only paid £350 for my E51 fully comp with all the bells and whistles too.
I am nearly 49, full clean licence, NO points EVER ( just jinxed myself now ) LOL, never made a claim in 30 years of driving albeit I have I.A.M advanced quals as well as DSA examiner/instructor qualifications too but none of them are recognised TBF.
Regards,
Richard Fox
Cheers in advance
Just checked mate @Brendan1969 and mine are definately AR16U, I even found the old box they came in! lol Clears the windscreen no problem!! A member on here has actually fitted a 17" blade!
This will help with the Nexbase Dashcam problem mate, a walk through how to install a dashcam!
I also have a Nextbase dashcam 312GW its been brilliant! Haven't managed to hardwire mine in yet, I need to get the kit first!
http://forum.elgrandoc.uk/threads/h...ia-fitting-kit-and-the-cig-lighter-fuse.6230/
Cheers Richard. I shall buy em now on ebay.
