- Isle Of Wight
- Colin
- South East
Why would such brittle, breakable, nonsense parts be fitted to machines. Chaos.
Difficult to make out in the pic whether the black area is melted or fallen away (we know some of it fell away because you removed it from the entrance to the rear cat) or just carbon...?Photo of the inside of the front opening of the rear catView attachment 93987
Photo of the exhaust before the cat View attachment 93988
I didn’t have a torch but it was flecks of carbons stuck to the honeycomb, I believe, and when looking through, barely any lights were shown through the honeycombs.Difficult to make out in the pic whether the black area is melted or fallen away (we know some of it fell away because you removed it from the entrance to the rear cat) or just carbon...?
Would be best toReporting that the car performance came back after decoring the rear left cat.
unsure if I should do the rear right one as well
I'm unsure how underseal relates to cat failure?THIS IS NOT FORUM LORE. THIS IS NOT A MYTH. THERE HAVE BEEN MANY DOCUMENTED INCIDENTS WHERE OWNERS HAVE HAD THEIR ENGINE BLOW UP BECAUSE OF THIS ISSUE. YOU HAVE BEEN WARNED.
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
3/ By far the most expensive option, but still an availability if you have the funds to allow it. Replace the WHOLE system (Manifold back) with a custom made stainless exhaust with single stage, high flow metal sports cat. Dig deep for this one, but the noise will be worth it - This option will 100% remove the risk of damage caused by the standard catalytic converter failure problem.
But what about.......?
Is this legal?
Why does this need doing?
With that in mind, discuss the options available with the garage you chose for your underseal and discuss repeat applications and how often they will be required. If they want your continued business, they will offer all options and tailor the service to your requirements and budget
I think he is talking about two different things that are recommended to be done (the underseal in england as I assume they spread salt on the road to clear the snow which would rust the chassis) The underseal thing isn't applicable to us in AustraliaI'm unsure how underseal relates to cat failure?
Is cat failure only an issue in cold climates?
Darn. I thought I had cancelled out a problemI think he is talking about two different things that are recommended to be done (the underseal in england as I assume they spread salt on the road to clear the snow which would rust the chassis) The underseal thing isn't applicable to us in Australia
Just wondering if you've found a mechanic who will do this job? I don't know if it's legal in Oz to disable the cats.I think he is talking about two different things that are recommended to be done (the underseal in england as I assume they spread salt on the road to clear the snow which would rust the chassis) The underseal thing isn't applicable to us in Australia
It has 2 inline on each exhaust pipe, if you get the rear cats gutted they still have one on each side. So it would pass an emissions test. I'm not sure if it is 'legal' though. Literally any exhaust shop would be able to do it for you.Just wondering if you've found a mechanic who will do this job? I don't know if it's legal in Oz to disable the cats.
Good to know, thanks.It has 2 inline on each exhaust pipe, if you get the rear cats gutted they still have one on each side. So it would pass an emissions test. I'm not sure if it is 'legal' though. Literally any exhaust shop would be able to do it for you.
City/southside for me. Not overly mechanically minded, but it seems like a very sensible thing to get done.@Skaface reckons any exhaust shop would do it. I'm in the northern suburbs how about you?
I believe they are the rear (toward the middle of the car)Hang on a minute....
@randomorbital I presumed the last pics you posted above were of the front cat (I should have read your post properly).
Have you done anything about the front cat on the passenger side (the side that failed)?
