The problem
damage to the engine.
The PRIMARY cats are the problem. Through use, after heating up and cooling down, they start to deteriorate. This happens with ANY catalytic converter when they reach the end of the their life. As the PRIMARY cats starts to break down and fall apart, the debris is pushed back through the exhaust. At this point, they come into contact with the SECONDARY cats, which creates a blockage.
There are 2 main options.
1/ DECORE the SECONDARY CATS. This is a simple process. You remove the secondary cats, cut an opening in the top, smash the internals out, weld the opening shut again and re-fit them. This removes the point at which the debris from the PRIMARY cats will get stuck creating a blockage. The debris is just pushed out the back of the exhaust.
2/ Remove the SECONDARY CATS. Same principle as option 1, but you remove the cats altogether and replace with a straight through pipe. This is more costly than option 1, BUT what it means is that when it comes to MOT time, you still have the cats to fit to the vehicle if there are ever any issues.
But what about.......?
Is this legal?
Why does this need doing?
Adam Bracher
Hi All
New to the forum as need some advice really. Have had E51 since last June but been off the road since December as it began spluttering and then just died. Couldnt get it started again and had it towed away. The garage has spent last 6 months looking at it periodically and dont know what is wrong with it. They have got it going again, drive it, gets seriously hot, load of smoke out of the exhaust and thats that. Then i see the past above and i wonder if that could be it. Before the cats get blocked, would there be shuddering and lack of response? I think I will point the above post out to them.
The mechanics said that there is excessive fuel getting into the system but they dont know where it is coming from. I know i havent given too much info here, but any advice would be greatly welcomed as only drove it for 5 months and now been off road for 6!
Hi All
Sounds like a typical example of what happens when the cat system totally blocks. Unfortunately. Sorry we didn't get the message to you in time.
Imo don't waste any money on buying parts or anything else for this car until you know he engine isn't damaged (it is unlikely to not to be damaged tbh) once the blockage has been removed. Get the garage to split the exhaust between the cats and see if it runs ok and doesn't burn oil first.
Alan Morgan
Pretty much covers it!
Only thing I would add is on the legal aspect, you really should inform your insurers of this - as sensible a modification as it is, it is still a modification and it would more likely be viewed as a performance mod than cosmetic...
I'm not disagreeing about the theoretical legitimacy of telling the insurance company about de-catting but why open Pandora's box? If you de-core rather than de-cat, then the work isn't even visible let alone detectable (other than by dis-mantling).
'It's normal preventative maintenance... go look on the owner's club site' ;)
Alan Morgan
Hi @MrRob_in, the reference to Pandora's box is in respect of telling the insurance company, not the cat work which I had done within weeks of getting my Elgrand (and that was down to the info on here from the likes of yourself and others). For less than the price of a service, even if you're a doubting Thomas, why would you not get the work done. After all people spend many hundreds of pounds on insurance against other possible events, and this can be seen in a like manner.
That is fair enough but a stealthy decore is only one way of dealing with the problem. I didn't think this thread was aimed at those so experienced.
Nothing theoretical about it anyway. Yes the cat problem does exist and there are ways of sorting it. Personally, I wouldn't want to encourage something that may cause further problems to people who may not understand the possible consequences.
If the worst should happen, it is detectable even if dismantling is necessary. Unlikely to happen? Absolutely. Would I want it on my conscience that someone listened to my theoretical advice off the internet?
Insurance is a complete rip off anyhow, I wouldn't bother with it ;)
For the record I told my insurance co. They noted it just like tow bar, non oe but Nissan alloy wheels, Nissan Aero bib bonnet aero kit and airbags in rear suspension... no change in premium.
SQUIZ
Do you reckon i should inform my insurers that i have swapped out my radio,changed a wheel bearing ,waxoiled my Elgrand and ordered an extra keyfob ?Is it possible that my insurance is now invalid because of the work i have carried out.OH !! i forgot to mention that i used a liquid cleaner on the inside and have started to use a clay bar on the exterior paint,the clay bar is being consumed by the paint so therefore this could make the vehicle NOT AS STANDARD
SQUIZ
[COCKQUOTE="blingo, post: 48053, member: 219"]Absolutely, you should ring them immediately! I honestly can't believe you have admitted to all that on a public forum, they are probably voiding your policy right now. You might get away with a couple of those mods if you are really lucky. It obviously depends on whether the keyfob still has the original battery. And as everyone knows, the claybar use is very much an insurance grey area - depends entirely on what lubricant you used. I suspect you might be using an unapproved one if the bar is being consumed by the paint though.
You know what is actually funny? That you can't see the difference between any of these things and removing the cats.[/QUOTE]
Ah !!! You are telling me what i maybe able or unable to see.Are you an optician who doesn't need to measure peoples vision physically before diagnosing sight problems ? Please advise on exactly what or how one may invalidate their insurance by looking after their vehicle , whether it be cosmetic or to prolong the life of the vehicle,whether mechanical or cosmetic .ie.if a vehicle manual states semi synthetic oil and one uses a higher grade fully synthetic oil will this invalidate insurance ? T
Travellingman
anything that was not fitted by the original manufacturer is a modification , tow bar , fancy stereo , conversion to camper , ie , sink , cooker , fridge , a decat is a modification , so , if you prang it and the insurance company find its got a cat or 2 missing then your up cat creek without a paddle , washing it , detailing it , hoovering it , are not mods .they are just things you do when you should actually be driving it .
LLGrandJ
Admin / Disc Jockey
Can I just double-triple-check this doesn't apply to E50s with the VQ35DE engine? The wiki seems to suggest it does...
Travellingman
Blatantly obvious , If I do it its fine , If someone else does it its questionable , If the Law says it its Optional , If a Mate says it its Gospel Truth , If the Wife says it its Mandatory , If a non driver says it its Crap , Facts discussed in a Pub are much more Scientifically Correct than any Info from Stephen Hawking or that Einstein guy , If an Insurer says the answer is Modified then maybe you shouldnt have asked the Question in the First place ?
plead ignorance and just say it was Foreign so you thought it was a "standard fitting "
#16
No, the cat issue does not affect the E50 as the E50 only has a dual cat system, not a quad cat system.
As for the rest of this thread, what a pointless debate it is.
Yes, if you remove or de-core the cats, this is a modification that needs giving to your insurance company. This is a modification to the original design specification of the vehicle itself.
Yes, you should also tell your insurance company if you are using bulbs or oils that are NOT recommended by the manufacturer. But in the event of a crash, they are not going to test your oil to see if they can determine a brand and oil type. They will, however, check for common modifications to get out of paying out. Insurance companies know that people remove cats for performance reasons... they also know they get de-cored. Just because we happen to be doing it to prolong the life of our cars, other people with other vehicles do it for performance reasons. As such, cats ARE a hot topic for insurance and something they most likely WILL look into in the event of an accident.
blingo
I really didn't want to start an argument and have deleted my posts. Was only trying to help.
SQUIZ was actually right, I am a cock. And if treated like one, I have a habit of becoming a bigger cock. But it isn't helpful and promise not to get drawn in to it again.
The only reason I brought it up in the first place was because I thought some people wouldn't realise that it is something that insurers do look out for.
As you said, pointless. In all honesty, I briefly considered a "rage quit" on here.
Fortunately I do see the value of what we have here and the knowledge that others have. More importantly, I'd be f**cked without it :)
Sorry, will take more than some smart arse comments to get rid of me.
SQUIZ
AN APOLOGY TO BLINGO
No you are not a cock,both you and i got drawn in by each other.I personally felt protective towards Sir Robin .who has so kindly put his efforts into helping people realise the CAT ISSUE. HANDS UP i was a cock too,so would like to push this one under the bridge. Sorry if we didn't see eye to eye but hey life is too short for arguing. I have respect for every person using this forum and for every Elgrand owner.Sorry if we got off on the wrong foot .
blingo
Apology accepted!
You are still wrong though...
I am a cock :)
