Son just called me into the garage and guess whats just happened!!!!
Few weeks ago he had the two suspension top mounts replaced due to the mini be lowered and causing pressure on the mounts.
Then a few nights ago he managed to source a strut brace from his mates for €50 which was a bargain!!
He took it off to remove the paint and polish it up as it was bright yellow and then goes to refit and guess what one of the bolts shears off the suspension mount!!!! WTF!!!! Brand new part and my son only tried to tighten the bolt with a 3/8 driver!!!!
(Picture is from the internet!)
My son just called the garage and they said he must have tightened it too much!!! WTF
Trying to find out the torque settings for these poxy bolts but no joy, he told me he did not tighten them up that much!
Now he wants to use my Elgrand to go to Basketball tonight as his Mini is out of action!!!
My son stole my nut from my bonnet as he said my Elgrand won't be on the road for a while!! lol The nut did tighten up and apparently it should be torqued to around 25Nm, I did spot that he used my 1/2 inch drive rather than a smaller driver!!!!
Do you think this will be okay to use in its current state? The guy from the Mini garage said to drive it very carefully if you have to!
Well looks like he's got to borrow the Elgrand tonight as his steering pump is also leaking and has no fluid left in the steering reservoir!!! Wow BMW's I thought were good quality cars seriously.......!!!!
