Hi, the dealer I am purchasing from has said that the cars have been sorted. Is there anyway I can check this and confirm it for myself?
I would ask them what they mean when they say the cars (assume you mean cats?) have been sorted. What are they saying has been done to sort them?
yes sorry! I meant cats and they said they had been decored
Any mention in their Elgrand ads about de-coring as standard prep on the E51’s they sell ?
I’d ask for evidence the cores have been removed if it’s just say so - a photo maybe or the welds .
If they get funny you asking , I’d have doubts
I had mine de-cored at Tojo soon after buying , dealer was clueless about CATS & I made sure the fog light was fit in the o/s reverse light
Where is your fog light position ?
Hope all checks out for you & you love the new motor 🙏
Yeah it says “removed cats” so I’ll check to see if I can see them actually removed and if not then I’ll make sure about the de coring of them. And they have fit the fog light into one of the reverse lights and out a button in just on the right of the steering column
Should have the forms and plates from the dvla this week so hopefully picking it up this weekend!
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
But what about.......?
Is this legal?
Why does this need doing?
Hi Karl, a thoroughly good read, answered all my questions in one go, Shame it has to be done was only told by the garage that did the gas conversion after I had the work done, so more expense, thinking I'll go for the decoring option.
Many thanks for your article.
Dave Lewis.
Dave Lewis.
Having given this a large dose of thought I would like to remove both cats with replacement pipe work and put the problem to bed once and for all.
Can anyone recommend a reliable supplier of the pipes to do the job , as a retired plumber I feel I can have a go at this myself.
Many thanks in advance.
Dave Lewis.
im getting mine done by a power flow agent near me that will be front cats replaced with 400 cell, rear cats bined (mine are empty) then a y peice into silencer then pipe to back box all for £1250 and lifetime guarantee
Personally I'm looking to remove just the rear cats and replacement piping run to the rear on both as having only just aquired the van, paying to have a lpg conversion done and several other purchases such as a large awning.
Hopefully it will eliminate any future problems.
Dave Lewis.
ah right maybe have a word with your lpg installer
Thanks for the reply, I did Sk the gas conversion installer but he is so busy and has 3 months lead time.. So far the conversion has been a success and as far as I know runs the same as petrol
Hi! I tried to search, but I couldn't find information about such config: decored front cats and original rear cats - is it pass the MOT or not?
Can anybody prove it?
If it still pass the MOT it seems like safest and easiest config.
Plenty have decored or removed front cats with no resulting impact on mot. Two cats, either front or rear is all that's needed for UK emissions test.
I had my rear cats removed when I first got mine and it's sailed through 3 mots since.
What "proof" do you expect?
So… when the dealer I just paid a deposit to, told me there’s no need to decat or decore if you service regularly… he was talking out of his rear end?
Unless it's an E50....yes.
