Thank you very much for the advice Steve, greatly appreciated.
So based on that as well as what I’ve seen on the forum I should really take him up on the offer to remove the two rear CATS for £150.
many thanks
Simon
I'd say so could still fail but your chances are better than leaving them all in
many thanks
Simon
Personally I would go for front cat removal and LPG.
As it stands most likely possible option is removing the two rears CATs, has anyone had experience with passing MOTs after removing the two rear CATs or did they fail?
From memory most pass the odd 1 fails
I had my rear cats removed 10 years ago, and because I knew no better, they cut the flanges off the cats and fitted Stainless pipes in place. Never had a failure due to emissions..still have the flangeless cats in the garage!!!
Thank you very much! Does help to give us piece of mind!
Both rear cat inerds removed and welded backup upon import, never had a problem with emmisions and passed both mots since getting her 👍🏻
Thank you everyone for your comments/answers. Rear cats removed and collected yesterday. Looking at the different options available now re Japanese>English for the units, reached out to the companies in New Zealand and Estonia so hopefully sorted soon.
cheers!
Hi all, new joiner. In the final stages of buying my first Elgrand it is a 2009 E51 Fresh import. Stumbled across this forum last night and found out shockingly about the CAT issue and emailed the dealer last night.
They’ve said the car has all 4 CATs as this issue only affected the earlier models with a factory recall to update the ECU, they’ve offered to remove the rear CATS for £150 extra but don’t think it is necessary as none of their previous customers have had a problem. They’ve also mentioned the extended warranty doesn’t cover exhausts which I assume would also include this.
would appreciate if anyone would be kind enough to offer any advice?
Many thanks
Simon
Hi Simon I am now in this exact same position with my dealer. He too has offered to sort the rear cats out after I found out about the issue on this amazing forum and quizzed him about it. As soon as I asked him he knew of the issue. From what I've read so far on here it's probably better to be safe than sorry so if the dealer doesn't sort them out I am planning to have a mechanic friend remove them and depending on cost I'll either plump for the replacement pipes on eBay or go for a new system. Will prob eventually get the front two checked too.
I’ve mine for 6 years & all 4 cats are in situ. Never had a problem & won’t be removing anything until advised to do so by my qualified mechanic. I got my Elgrand from the main Scottish distributor of Elgrands, at the time anyway, & they hadn’t had any warranty issues with cats failing, engines exploding etc. I don’t doubt that some vehicles have problems regarding this issue but not every Elgrand.
I’ll put my tin hat on now & wait for the inevitable barrage………
Which qualification would you like and il clumb in loft to dig them out well regarded issue on all cars mot just elgrands expected life in nominal use is 10 years
Your car, your choice. Its certainly not the law to decat.
But, bearing in mind dealer warranties normally last 3 - 6 months, I'm not surprised the dealer hadn't experienced any warranty issues due to cats.
All cats will fail in time and with the Elgrand quad system, there is an inevitable outcome that the rears will block when (not if) the fronts break down. Its just a matter of time. The choice for me was spending a little as a sort of insurance or keeping my fingers crossed that they didn't give up the ghost while I still owned the van. Easy decision on my part 😉
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
There are 3 main options.
But what about.......?
Is this legal?
Why does this need doing?
Thanks for the information!
No, because no one in there right mind drives or admits to driving one long enough without removing the rear cores to worry about mpg with them in.
Honestly in same conditions you can drive the same route and get 18 to 28 mpg depending on your right foot, how the heck anyone can say doing X saved 2 mpg without removing all the other variables is beyond my comprehension.
That’s a shame, I put £100 in the tank yesterday!!
