The E51 l have just bought has had the rear two removed.
Rear as two that are further away from the engine?The E51 l have just bought has had the rear two removed.
YesRear as two that are further away from the engine?
Thanks
Dont think it's really noticeable.Hi, our E51 goes in tomorrow to have the front cats decored. We will keep the rear cats and in a months time get LPG installed.
Will decoring the fronts make the van much louder?
I wouldn’t of thought u will notice any difference, that’s way I would go if I ever had a e51Hi, our E51 goes in tomorrow to have the front cats decored. We will keep the rear cats and in a months time get LPG installed.
They didn't come up with a solution. Yes there was a recall for cats but I (and others on forum) reckon the recall did nothing to change the cat situation. They may have checked cats during the recall but they didn't change them unless faults were found during the check - which won't be a great help if the problem is a design problem as it seems to be. Plenty Elgrands that have had the cat recall done have had cats fail on them since. Easy to think Nissan whitewashed the issue, stall tactics until the warranties expired. All cats will eventually fail but cat failures don't generally lead to engine failures as is the case with the Nissan E51 design.Did they not come up with a solution to the catalytic converter problem in Japan? I know the rules are stricter regarding emissions over there so they couldn't remove any of the cats, but surely they must have had a solution? Werent they recalled?
Yes all in the diary, not sure where this year is going. Looking forward to getting all doneDecoring all 4 cats on an E51 doesn't make noticeable difference to the exhaust sound.
You booked in for LPG conversion with me for 27th June (this month ) @Cjhdc5 ?
No sensors on the rear cats. No problem with replacing them with straight pipeis there any sensor in the rear cat ? or i can just ask my garage to replace them with a strait pipe ?
Same here dealer said not necessary...?So… when the dealer I just paid a deposit to, told me there’s no need to decat or decore if you service regularly… he was talking out of his rear end?
Tenner?Bugger-Does anyone want to buy my van?
