Maybe not, it's hard to say what damage has been caused up to now.
If it was me though I'd chance it, fairly easy to get exhaust welded back up again and if hate to be leaving my van in a layby somewhere
SO I decided to cut the pipe open. Sure enough the passenger side Cat was blocked up with a good chunk of debris (other one was fine).
I have now freed it up and it drove home fine (although sounding very loud due to the holes in the exhaust)
Its hard given how loud the exhaust is now tio work out if ther engine sounds ok or not.... but it drove ok.
What would you do next (apart from de-core the cats.. ha ha) get teh engine checked I assume? What should I be asking somebody to do to check it? (as you can tell I'm not that mechanical)
Get the exhaust repaired, see how she sounds... You may have been lucky.
You may experience higher oil consumption now though so keep an eye on oil levels...
@Whaley Get exhaust welded up after they are decored , check your engine oil is correct level , first start car and check exhaust to see if u are burning oil (blue smoke ) then drive car and see if any different, keep eye on gauges, keep watching rear for smoke , if car is smooth just drive it as normal but check oil on a trip basis , u will no straight away if u have been lucky , fingers crossed
Even if u are burning a little it’s better than a goosed engine
So apart from oil consumption anything else to look out for?
And when people say a goosed engine - do they not even drive?
I can't believe that I'll get lucky (born pessimist) so how else will I know? or will it just lose power/not have any power?
Sorry for all teh queries guys (and Gals)
Burning oil would be the first sign, so blue smoke , a few people on here have got lucky so hopefully you have too.
Some engines just burn a little oil , some rattle like a washing machine full of nuts and bolts and some are seized solid , I call the last two goosed , if u have melted the engine you will know , no power or won’t even run at all , even with holes in exhaust you will hear if running smooth , gd luck
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
The PRIMARY cats are the problem. Through use, after heating up and cooling down, they start to deteriorate. This happens with ANY catalytic converter when they reach the end of the their life. As the PRIMARY cats starts to break down and fall apart, the debris is pushed back through the exhaust. At this point, they come into contact with the SECONDARY cats, which creates a blockage.
There are 2 main options.
1/ DECORE the SECONDARY CATS. This is a simple process. You remove the secondary cats, cut an opening in the top, smash the internals out, weld the opening shut again and re-fit them. This removes the point at which the debris from the PRIMARY cats will get stuck creating a blockage. The debris is just pushed out the back of the exhaust.
2/ Remove the SECONDARY CATS. Same principle as option 1, but you remove the cats altogether and replace with a straight through pipe. This is more costly than option 1, BUT what it means is that when it comes to MOT time, you still have the cats to fit to the vehicle if there are ever any issues.
But what about.......?
Is this legal?
Why does this need doing?
Thanks for the info on the CATS. I shall be removing them altogether ASAP just to be on the safe side.
Opinions: Will a new set of rear cats clog just as easily as an old set? Asking as I'm viewing a potential purchase where the owner has replaced rear cats and not the fronts. It'll be a long drive home and I don't want to fuck it up.
If the front ones haven't broken up yet then yes they could.
Yes, if the front cats give up they will block anything other than a straight through pipe. Depending on whether the fronts give up slowly or whether they have a sudden catastrophic failure will depend on how quickly they clog the rears, so you may get lucky with new rears, but get rid asap.
Get him to clarify what he replaced them with. Maybe he replaced them with straight through pipes.
Yeah I can't imagine he paid for new replacement cats, that would be very expensive
Has anyone got an MOT running on petrol without front/both sets of cats?
Be interesting to see when front ones break up if they actually need to be replaced.
Yes mine passed Tuesday. No issues. Have full system by Powerflow.
