i didn't I was talking about the big white box lol i bet some of the buttons dont work on the jap version anyway, or have I got the wrong end of the stick...
the white box thing holds wires inside it and it clips onto the frame that holds the unit in place
that makes sense.... how you sorting the button issue...?
Well i thought right that the buttons are not made in english for this control panel, i also called them to ask and they said send buttons and they will repaint and put stickers on for $100
think i will try and come up with something myself
keith
So the button works? but it says the wrong thing on each button? is that what you mean... the photo as the buttons with the wrong names on each buttom, did you replace the control panel from the one you bought or just the buttons on to the old one...
how about re-spraying them in total with a stencil in place ( say vinyl) saying the correct function, then peal of the vinyl stencil to reveal the correct words, dry run with the Jap buttons you already have...?
yes all the buttons work i think, just that they are worded wrong, the video that i watched had a panel the same as mine before they changed the buttons bit annoying moved buttons from the one i bought to the one i took out as the new one does not fit into the dash
thats what i am thinking need to find very small vinyl letters
you may see on some of my other posts I am a enthusiastic Amature designer, all the gear and no idea lol, but yes I can cut you those no problem...
only button that does not work is the carwings one i think they say that on they site
ok well i have the buttons sitting here and i know what needs to be where
in a way it works as a way of turning of the screen when a video is playing, when you press that one what happens, we can come up with a word for it so it looks better lol
Not sure if you can see but nothing is right not even close
we can take this to a conversation/ message bud, i cant read most off that... sorry..
i will do a blank version photo of mine...
Here you go, i will send it you too..
Obviously we have to sort out the size and font etc, i will use best font to suit the size we settle on, because at that size they will end up very fiddly to weed (cut and then remove from backing) but I will let you measure the size of the ones you have and I will mock it up to see if it works before I cut anything...
Are the buttons backlit?
Hi Chris no they are not backlit they have been laser engraved if i hold a button up to the light a can see through the wording
So the writing needs to be transparent?
