- Billingham
- Karl
- E50
- North East
Simple answer is no. The standard Elgrand In Car Entertainment hardware is designed for use in Japan only. The Sat Nav is for Japan only, the menu's are all in Japanese, and no, there is no way to convert them to English.
I believe the later S3 E51's and the E52's have a solution available, but I'm not too clued up on it.
You can either learn to live with Radio 2, no sat nav, and managing with the standard set up, or you can apply some of the work arounds/solutions to resolve this.
The simplest method, but only available to those with the AV pack (meaning you have Audio/Video inputs on the drivers side in the rear door card) is to get an external DVD player that you can set to output in NTSC (UK is PAL) format, and then whatever you play will come through the screens.
For those who don't have the AV pack, or want something a little more permanent, you will need to look into replacing the standard head unit.
There are guides in the "how To" section that will talk you through replacing both E50 and E51 hardware for UK spec (or local spec whatever country you're in) including wiring requirements, things you'll need, etc.
