windscreen's
This is what the heat pack rocker switch looks like. Obviously you'd only see the front if it was in a van.
That small silver button is the front parking aid I believe!
The little pop up aerial thing? That’s what I’d assumed too, but my aerial is just loose and disconnected so can’t prove it one way or the other.
Mine got that thing at the bottom of the windscreen too, but I haven't got anything heated.
If you have the cold weather pack , the wiper and mirror heaters come on when the rear screen heater is turned on ( I think)
You’ll probably only ever notice them working in freezing conditions
just spotted there seems to be heating elements directly under the wiper blades. I don’t have an under dash button so I’d assumed I didn’t have this option.
Sounds exactly like mine
worst pic ever, but these are the 'lines' at the foot of my windscreen.
Mine literally sit under the wiper blade and you can barely see them unless you lift the blades up. Certainly don’t look as thick as that.
EDIT - just realised that’s a reflection of your finger and not the actual size of it! So yeah probs the same 👍🏻
That’s good to know. But why do some have a dedicated rocker switch?!? Honestly, these vans are crackers at times 🤪🤪🤪
That's what made me think too. I'd kind of dismissed it as not having one, as I also don't have the rocker switch, but then this thread makes me think otherwise. I've only used the rear demister switch once, last Tuesday morning up the Brecon Beacons, but I wasn't paying attention to if anything was happening on the front. I had read once that the 'heat pack''s heated windscreen only does by the wiper blades.....which is what we've got.
I'm going over to Colin Prices again sometime thing week, to see if the service bloke is back after being ill (he's scheduled to be), so I'll have a look at a few on his forecourt.
I’m just going by what I’ve read on here myself in the past.
Mine only has heat on the wing mirrors not the front screen and no switch, so maybe a switch could be for screen , I don’t know
Do yours have any visual indication (lines/symbol etc) that the wing mirrors are heated, or did you just find out via using the rear window demister?
That helped me out actually. I learn something everyday too.
I wondered, the other day when I had the rear demister on after a degree C camp, why the rear side back windows weren't defrosting, but I kind of forgot about it by the time I got back. That must explain it- they're not heating things :)
That's what I love about the Elgrand OC we can all help each other, with the bits of information we know, and you don't get abused if you get something wrong, everyone is so friendly. Not like on FB.
Just noticed them steaming one cold cold day, after I’d scraped all screens etc lol
Apologies, thought it was on the column itself but just below instead.
I'm not sure what that button is, and I don't know what Elgrand you have. I was checking because I have a S2 Rider S and I have a small button that controls the footwell lights in the front and the small lights that are on the B pillar in the back. It changes their colour and can even make then run through a changing sequence all on their own. It took me ages to realise what my small button did because I didn't want to press it not knowing what was going to happen. If you haven't had your windscreen changed yet, maybe try it and see if it does demist the screen. Or maybe someone else knows what your button could be. It may be something the previous owner fitted, and it will be trial and error to see what it does. Sorry I can't be more helpful.
Here is a photo of my footwell lights button, it's the button circled blue.
just had a look on the Autoglass website, a chip repair cost £225 😲 still, cheaper than a grand for a new one. :rolleyes:
Just had a heated screen with sensor fitted in a mates ford, 260.
That's the one (the yellow one) which will auto dip the mirrors when you go into reverse. If yours don't do that, it'll be in the 'off' position. Next time you get in it, flip it and go into reverse. The side mirrors will dip.
