Side door rattling?I've got an unidentifiable knock when going over small bumps ... or my van has (I've got plenty of knocks, rattles and creaks).
I've taken it to two garages now, both have given all the suspension, bushes, droplinks etc a good check, prod, push and everything is solid with no play.
I know I've just gotta wait until something manifests, but it's doing my f'ing head in.
Loose change in your pockets?I've got an unidentifiable knock when going over small bumps ... or my van has (I've got plenty of knocks, rattles and creaks).
Nope, definitely lower frontSide door rattling?
Nope, none left ... I'm an Elgrand owner.Loose change in your pockets?
Bank notes don't rattle ;o)))))Nope, definitely lower front
Did they jack it up to check play?I've got an unidentifiable knock when going over small bumps ... or my van has (I've got plenty of knocks, rattles and creaks).
They test drove it, put it on the two post ramp and then the four post ramp (so it had full weight). They even checked the joint at the bottom of the steering column but nothing found amiss.Did they jack it up to check play?
Yeah we had an issue with droplinks (and anti roll bar bushes), it wasn't evident whilst on the car but took them off and they were knackered.Did they jack it up to check play?
So annoying when you can't find a noise. Your Wife's earring perhaps?They test drove it, put it on the two post ramp and then the four post ramp (so it had full weight). They even checked the joint at the bottom of the steering column but nothing found amiss.
It happens when she's not in the car.So annoying when you can't find a noise. Your Wife's earring perhaps?
The Elgrand is my mistress, I can't afford bothMistress's earing
Hmm you didn't laugh so you don't remember the old VW advert with the earring.It happens when she's not in the car.
Work harder or find cheaper women....... ;o))))It happens when she's not in the car.
I'm not sure if you're joking or not but I am curious so I shall just ask.If I'm younger than you I'd be most surprised. I can remember television before there were adverts.
I have little for anyone to be envious of so just for you:
If I did that I'd have to get some contact numbers from you.Work harder or find cheaper women....... ;o))))
Well I've just proven myself wrong. I can't possibly remember this, but I don't recall seeing adverts as a small child. My parents obviously stuck to BBC.I'm not sure if you're joking or not but I am curious so I shall just ask.
Was there really a time when there were no adverts?
