I usually see my daughter on a Saturday through most of the day but didn't see her today as she has been off school poorly (not covid) for a couple of days.
So I looked at an Elgrand I LPG converted a while ago, owner said it had started not switching to LPG and I did witness it not switch to LPG... but then it behaved perfectly and always switched. There was no thorough disgnosis to be had with it behaving properly and with the LPG system not reporting any errors, so I swapped the tank valve solenoid, the engine bay solenoid, the pressure sensor and the ECU.... Swapping that lot should ensure the same doesn't happen again even though there was nothing pointing to any of those components having a problem.
Then I finished off fitting the towbar I started on Friday, I always advise customers that if they think they might want a towbar in future, get one fitted either before LPG conversion or ask me to fit one at time of LPG conversion, or otherwise most towbar fitters (including myself) will have to lower the LPG tank during fitting the towbar which is unecessary extra work if only things are done in best order. I supply and fit towbars but this owner had bought his own, before arranging a date/time for fitting the towbar I asked the owner what electrics he had bought (as in 7 pin, 7 pin with additional socket for caravan electrics as in 7n and 7s electrics, 13 pin, normal wiring or isolation relay wiring, did he want 'caravan' electrics (for charging caravan battery and powering a caravan fridge etc) in case of 13 pin, etc. He didn't know if he'd even bought electrics with the towbar. But when it arrived on Friday he'd bought the 13 pin with isolation relay that needs a 12v feed and with 'caravan relay'. So the job of fitting the towbar electrics involved running wires through the car to the battery, and to access the grommet in the firewall to run the wires through it means removing the wiper mechanism. Wouldn't usually expect to remove a vehicle's wiper mechanism during fitting a towbar.
Then next week I have 2 Elgrands to convert to LPG (as usual). But next week I have a dentist appointment, and an MRI scan at a local hospital. So to ensure I'd have enough time to get my work done next week today I had to modify some tank valves, fit valves to tanks, purge air out of tanks, fill tanks with a little LPG for testing purposes, and make up some pressure reducer assemblies.
Yesterday morning I thought today might be my first almost work free day for a long time, instead I still worked 11 hours.Simon @Lpgc; I’ll not bug you again trying to
