Was it hard work, or easy?View attachment 101068 View attachment 101069
View attachment 101070 View attachment 101071
EASY-HANSA has left the building...![]()
Brave man AndyWTF.
In for a penny in for a pound as the saying goes.
If you don't hear from me for a week come looking for me as I am just about to tell Janet I have just ordered these.
Dezent - TV dark (Black / Polished)
SIZE PCD CENTRE BORE OFFSET LOAD
8x18" 5x114.3 71.60 35.00 930kg
And going to be wearing these.
They will look great Andy, I hope telling your good lady isn't too painful.WTF.
Those are top notch, the Premium Contact 7.WTF.
Can't leave us on that cliffhanger....give us the details.Last wash. polish and ceramic coating applied before she goes up for sale.View attachment 101087
I love this addition, looking to paint ours in the next year.if someone can find photos of @kermits e51 she had orange and it looked good so dont get down @Carolina just go suttleView attachment 101039View attachment 101040
this is mine in blue front grill as well
I'm sure someone will be along to help you with your technical questions but in the meantime are you sure you should be driving on the left side of the road in CanadaSince we drive on the left side of the road here in Canada
I'll give you the long story. Purchased an e50 that was not running. Would start, sound great for first 5 seconds in high idle then die and smell like fuel. Did all the other stuff like all new sensors, distributor, plugs, wire, fuel filter and pump etc etc. Nothing changed. Finally ripped plenum off and fuel rail thinking fuel pressure regulator or injectors. To my surprise found number 1 injector port full of fuel. Could put a 4 inch screwdriver in all in fuel. I thought I had found my problem ( a leaking injector ). Took spark plug out and cranked it to clear fuel. NOTHING all fuel still to top of injector port. Obviously inlet valve not opening. Removed timing cover etc and seen rhs cam gear backed out and belt slipping forward on lhs cam gear. Turned over crank with a socket. Crank and cam gear spin but cam didn't. Was snapped in front journal. Just ordered a cam from a wreckers today. Now is the fun part to see if the vg33e is an interference motor with bent valves or a freewheeling motor. Lot of debate out there. Ordered a $15 borescope camera today as well to check out valves in closed position to see if damage. The vg33e sounded like a Swiss watch for first 5 seconds running on 1 head, could even feather the pedal and get it to 3k revs without any valve noise.did it snap ?
Actually doing a google search on that engine I seen a few that snapped in same place. I was hoping it just broke the cam gear dowel and gear spinning freely or the gear bolt was loose and backed out. The interference engine stuff is highly debatable from my research. Apparently this engine has lower lift cam and deeper cut outs in pistons leaving a tiny gap that can save you if not under load heavily. Old owner says happened on an offramp low speed apparently. Who knows though. Can only keep fingers crossedyikes !!!! its not often a camshaft snapes !!!! I hope the new cam does the job, good luck.![]()
Old owner said driving and suddenly lost power on offramp. I just assumed crank sensor or distributor/cam angle sensor etc.Actually doing a google search on that engine I seen a few that snapped in same place. I was hoping it just broke the cam gear dowel and gear spinning freely or the gear bolt was loose and backed out. The interference engine stuff is highly debatable from my research. Apparently this engine has lower lift cam and deeper cut outs in pistons leaving a tiny gap that can save you if not under load heavily. Old owner says happened on an offramp low speed apparently. Who knows though. Can only keep fingers crossed![]()
But the happy result you were out driving your Elgrand.Gave it a wash and took the dog to Caerphilly. En route topped up with ESSOs 99.
19.7mpg the (sad) result![]()
