- Hull
- Matthew
- E50
- Yorkshire
Always a job on the e50 Boris keep plodding on at it mate
Possibly easier to raise the garage? (I'm half serious)(I know that the engine should be lowered, but my garage height does not allow). Ideas to disassemble the front, dismantle the radiators and cut the body in front and pull the engine over the top).
An interesting idea) but my garage is concrete and redoing the roof is too expensive and time consuming.Possibly easier to raise the garage? (I'm half serious)
I wish you well with it - your ability to mend things yourself is inspirational to me.
There are a lot of reasons. I want to fully service the internal combustion engine - replace all gaskets, all seals, possibly oil scraper rings on the pistons. You also need to deal with oil leaks. it is also necessary to weld the engine mounting points, very large corrosion. Service the steering rack (completely disassemble and replace the oil seals and plastic bushing), service the front gearbox. Automatic transmission - replace the oil seal. Disassemble the transfer case and replace the seals and bearings. (there was a beating on the front cardan, but not in the crosses).Definitely doable if you cut the front bar and weld it back afterwards how come you need the motor out
Hello. no, that guy is not meElgrand is suitable for moderate off-road use. Transmission, automatic transmission, engine (QD 32) - ideal for 4x4 trips.Hey my friend, Are you the guy who posted the lifted Elgrand videos on YouTube a few years back?
They convinced me that an Elgrand has good off road abilities and will be perfect for what I want to do here in the UK.
After all your heavy duty work you're going to have an Elgrand Autobot from Transformers
I'm very hopeful)Lots to do but will last for many years
Yes, El technically will live for a long time .. But cosmetically ... It's hard to say)))nice one great to hear it still lives
I would say that this is a very long repair) Too many defects due to corrosion ..
Unfortunately, when I bought the house, the garage had already been built by the builder. And this garage is designed for a "city" car - a sedan .. Pit can be dug up, but getting into the pit will be problematic, Elgrand closes almost the entire garage)If you can't raise the workshop roof can you make a pit inside? You could make one outside if you have something to cover (Tarpaulin?) the pit area.
