- Scotland
- David
- Scotland
Please do
Email address:-Please do
Cover your hole with this.The little hole that has been taped over is directly under the screen
View attachment 100055View attachment 100056
I'll have a look, thanks.
Am i to assume the 4 studs on the inner side form a "touch" connection then?I thought it came out up to the connector block, but looking back it was cut and spliced at the RED arrow.
GREEN screws release camera.
BLUE screws split unit and holds trace ribbon.
Yes, interference fit, the ribbon is brittle and will crack just by looking at it.Am i to assume the 4 studs on the inner side form a "touch" connection then?
Thanks, the camera doesn't seem to exist anymore.Some more photos on this post.
When you say 4 wires.Thanks, the camera doesn't seem to exist anymore.
I suppose the external dimensions are critical to fit in the original holder.
I believe so, I did type in 5v in the search bar but I know from experience both ebay and amazon throw up any thing they wantDon't buy that one, the camera has to be 5volt, apparently.
OK,My wires were the same colours from the camera to the Vans cable.
Apparently one of the wires gets rid of the reverse warning markings, so you don’t get two lots.
They look too deep but for a fiver its worth the play.Found these on Aliexpress
D and E show 5v supply but no idea about the signal format and whether it would be compatible.
Any clues?
Yes, I can just about risk a fiver.They look too deep but for a fiver its worth the play.
