Hi there,
Was the £90 to remove both rear cats, cut open the top remove the insides and re-weld?
My 2003 E51 done about 88000kms so maybe I should have the job done.
regards
jackh
Hi Jack, yes the £90 was for the whole job & it only took over 2 hours because they had an issue getting the section off on one side - so potentially would only cost £60 (if your garage charges £30ph labor)
Hi guys,
Thanks for the valuable info on the de-core secondary cats.
I am on the case and will get my local friendly garage man on the job soonest.
kindest Regards
jackh
Hi there,
Many thanks for the info, I will get the job done asap.
Just wondering... not sure what you guys do in the UK but compliance in Australia requires replacing the two rear cats. What my mechanic did was cut out the two fronts. Made no difference at all to power or economy, but at least my engine is still a goer, and boy, what a goer !!
I'm booked in for Tuesday to have mine done (plus a little extra) :D
Me too plus the little extra........goes up to the cats of course
Looked at a de-core, but decided to go for a custom built full stainless system.... just because.... I will keep the old pipes and de-core them myself to either sell on or keep for a rainy day!! Looking at a LongLife system full stainless removing the rear cats and it's around £660... I didn't think that was too bad but interested to hear thoughts....
I paid £400 for full Powerflow system.
Damn.. might have to have words with them then!!
Might be a daft question and only thought about it since I've had a full stainless system put on my E51 from the front cats but what's to stop any debris from the front cats breaking up blocking the exhaust box just as it would the rear cats?
It might differ from branch to branch but I would bother with Longlife unless you want to keep going back until they get it right. They do honour the lifetime guarantee but I've been back 4 times in six months!
There's much more room in the silencers for air to get round. They're also further back so the chances of debris getting pushed back I to the cylinders is virtually nil.
@G-train in your last post you said for compliance reason, the two rear cats are replaced: replaced with what I'm wondering? Are you say the old cats are removed only to be replaced by two new ones?
Thanks Monty.
I have owned 2 E51's now .. . removed 2nd cats on both .. .they go so much better with them gone .. .Km showing on Van means 100% nothing as was a recall in Japan ,, problem is if recall has in fact been done ...
1st van done 130K and 2nd cats were like brand new
2nd van brought at 180K (now over 200). these cats where 3/4 blocked ..
I dont buy on KMs a van/car has done but its overall condition .. .
MY higher Km van is far better than my 1st
Hi guys,
Got the de-core job on the 2 rear cat converters today - thanks for all the info.
regards jackh
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
The PRIMARY cats are the problem. Through use, after heating up and cooling down, they start to deteriorate. This happens with ANY catalytic converter when they reach the end of the their life. As the PRIMARY cats starts to break down and fall apart, the debris is pushed back through the exhaust. At this point, they come into contact with the SECONDARY cats, which creates a blockage.
There are 2 main options.
1/ DECORE the SECONDARY CATS. This is a simple process. You remove the secondary cats, cut an opening in the top, smash the internals out, weld the opening shut again and re-fit them. This removes the point at which the debris from the PRIMARY cats will get stuck creating a blockage. The debris is just pushed out the back of the exhaust.
2/ Remove the SECONDARY CATS. Same principle as option 1, but you remove the cats altogether and replace with a straight through pipe. This is more costly than option 1, BUT what it means is that when it comes to MOT time, you still have the cats to fit to the vehicle if there are ever any issues.
But what about.......?
Is this legal?
Why does this need doing?
Hi Karl,
This is good info.
Bought my 2003 E51 in November 2017 with 86000kms on the clock, she was imported January 2017.
Today I had the rear cats done and in January 2018 had a full Dinitrol job done on the under-body, wheel arches and box sections.
Question - is there any other items I should be looking at to prolong the life of my E51?
Thanks again and kind regards
jackh
Is there anyone in London Heathrow area that could do this job for me?
Top Bottom
