E51 E51 Aircon Pipe Corrosion (Rear)
Yes, if the Aircon is off you can blow ambient air through the rear vent but the air intake is internal so won't be fresh outside air like the front.
I've had the rear blank from BMR fitted for about 1 year and never had a problem. I even removed the rear heater entirly and all pipe work to make space for other goodies. I will probably fit a gas heater in that space to use only when stationary.
May I ask who you had to do the work as I am in Norwich please
I've recently had the blank from Brian (BMR) fitted after more than a year without being able to use the aircon because of the leak at the rear.
The mechanic said it was easy to fit.
I took it for a re-gas and they tested for leaks and re-gassed with 0.6litres and I drove home in comfort on a day where the temp was nearing 30.
A week later and all is well.
Thank you Brian.
The local aircon "specialist" backheeled the job because he said it would lake far too long to do because he would have to remove half the engine and then he'd have to make a blank....
Lazy Wassock!
Where does this blank fit please
My E51 is 05 reg and a fantastic workhorse. It’s had its problems like camshaft sensors going, but recently it has been pretty good. Then I noticed since we’ve had nice weather that the aircon wasn’t cold anymore. I took it to my local garage. They said they tested it fine, recharged it, I drive home fine. Next day nada! So back at the garage, they said yes we found a leak in the pipe going to back. It cost £790 + VAT plus labour. So I say, OK why not just blank off the front system pipes to the rear. They said they didn’t know how to do that. So now I’m stuck with no air conditioning with summer coming in.
Is there anyone who can help me with a fix like shutting off the rear system so at least I’ve got cool up front. I’m not into doing it myself at my age any more, so need help please. Is there an Elgrand specialist who can help please. BTW I’m in Chichester, West Sussex. Thanks in anticipation.
BMR does a blanking plate especially for this @BMR
You can blank off the rear with the adapter available from BMR. Check out the partner site links drop down menu.
