- Mid Yorkshire
- Simon
- Yorkshire
Cheers Simon - very insightful as usual. I did go through all the post (quickly but did) and picked up the point about the rear heater unit being in this area as well - that's why was thinking that might not be a straightforward - yes it's the AC pipe.
And yes by the box - I meant the external box with the flap (that I have on the picture - probably not easy to identify from this pic). Ok - will need to get somebody to look at it and confirm where the leak comes from.
And completely agree with you - I would rather have the back heater and Ac working (I assume the heater works if the back AC gets blanked - as you mentioned the AC pipes and heart pipes are different as i assume is on all cars?! - otherwise the car goes before the winter) - if there was somebody close by willing to do the work - I will happily pay for it - will even travel (although this becomes a challenge if it is too far but willing to do it to get it sorted properly). With young family (and baby on the way) and this currently being the only car this is not ideal by a long stretch but a reality with an old car and being a grey import. I take it if the rear AC gets blanked - it still can be sorted properly afterwards (with pipes replaced)? Although most likely the car ill be replaced before this happens.
If you are willing to sort few things out - happy to come and visit you and make it worthwhile for both of us (need a calibration of the LPG system as well - so can wrap it all up) .
Would like to help but I don't expect to get time to work on customer's AC systems anytime soon mate.
I have fixed the AC systems on both of my E51 Elgrands, both had the usual hole at the rear end of the front to rear AC pipe, I fixed them both by changing the front to rear AC pipe... Which involves lowering the back axle. But lowering the back axle isn't too difficult for anyone handy with the spanners, can be done on a driveway with a couple of jacks. Elgrand scrappers like Stevemen sell second hand front to rear AC pipes. Or as you know BMR sells the blanking plate (but blanking plate means the rear AC won't work). I don't have an AC machine here, I do have one of those Halfords DIY AC regas setups but would be better (and cheaper) to have the AC system re-gassed at (say) a Kwik-Fit. But of course Kwik Fit and similar setups won't get involved in fixing the AC.
Could probably see you a lot sooner for LPG system checks/repairs/putting right. I assume it's not one of my LPG conversions?
