Could you tell me which model you went for please.I purchased my pivot about 5 years ago they are brilliant and still works perfectly and simple to fit.
Have you any pictures of it.
If I remembered correctly I used a thin bladed screwdriver to release it I think the handbrake one was the worstAny tips on unplugging the brake plug? Had a go a few days ago and just couldn't get my hands around to the top of it enough to push the tab to get it apart.
Thanks. I'm still trying to weigh up what to order.There you go I made the button myself switches the cruise control in and out I think it’s the last 2 pins on the right you need to connect it to its non-latching switch.
Pivot 3 drive a I think they have updated it now
Ah right thanks I was trying to do it with a little screwdriver so I'll have another go with that.If I remembered correctly I used a thin bladed screwdriver to release it I think the handbrake one was the worst
Hi,Ah right thanks I was trying to do it with a little screwdriver so I'll have another go with that.
I don't think I need to do anything with the handbrake tho? Maybe it's changed slightly
Yes it's the pivot 3 drive ac2Hi,
Are you fitting a Pivot system?
Nice I will follow your progress keenly; would you mind telling me which cables you ordered there seems to be a bewildering array.Yes it's the pivot 3 drive ac2
I'm a series 2 (2007 model)3A (TH-3A) BR-3 or BR-4 depending on series.
It's Th - 3a and BR - 3 for my series 3.Nice I will follow your progress keenly; would you mind telling me which cables you ordered there seems to be a bewildering array.
I think it's a TH-3A & BR-3 but I'm not quite sure.
Thanks, I think I will have to have a look at my brake light switch tomorrow when its daylight and count the wires.It's Th - 3a and BR - 3 for my series 3.
HI, did you get it directly from Japan, can you remember what the charges were (customs, VAT, postage etc)It's Th - 3a and BR - 3 for my series 3.
Yeah mine came from Japan, I can't remember the postage but you can check on the website what it will be if I remember. Customs I think was about £70 unfortunatelyHI, did you get it directly from Japan, can you remember what the charges were (customs, VAT, postage etc)
If it's out of stock this is somewhat of a moot point, but I went for the CANM8 cruise control as it was the only one with a speed limiter - important as I live in Wales which is introducing widespread 20mph limits in 2023.I see people have fitted the Canm8 system and wondered if you had thoughts about it (ease of use reliability etc)
Speed limiter is an option that I never thought about, but can see how it would be very handy, ThanksIf it's out of stock this is somewhat of a moot point, but I went for the CANM8 cruise control as it was the only one with a speed limiter - important as I live in Wales which is introducing widespread 20mph limits in 2023.
The stalk that CANM8's come with is excellent, giving easy access to presets, last speed, speed limiter etc... very easy to use.
I've not heard of any problems with any aftermarket cruise controls on Elgrands, save for downshifting and higher revs than is needed on very steep hills... probably a feature of the Elgrand rather than the cruise control?
Yes, thanks to help from here. My only issues were with dismantling the Elgrand, as I'd not done that before. People that have already had the dash and steering column apart and are comfortable splicing wires or soldering won't have issues as the instructions provided for installing the unit itself were clear.Speed limiter is an option that I never thought about, but can see how it would be very handy, Thanks
Did you do the installation yourself?
Thanks, I looked on CanM8 website and like someone said before they have no stock.Yes, thanks to help from here. My only issues were with dismantling the Elgrand, as I'd not done that before. People that have already had the dash and steering column apart and are comfortable splicing wires or soldering won't have issues as the instructions provided for installing the unit itself were clear.
I posted for help in this thread:
https://forum.elgrandoc.uk/threads/fitting-canm8-cruise-control-stalk.30092/#post-420499
