If the high mileage E52's have been used as taxis it's interesting that the taxi companies used 3.5 E52's as opposed the more economical 4 cylinder 2.5 E52's... This is speculation but maybe rather than 'taxi' we're talking executive transport for airport runs etc, at a higher hire price than a standard taxi or lower spec vehicle, with profits high enough and level of 'customer service' high enough to warrant a very rigorous service schedule - Pete @WhatsThisFor 's scenario of multiple gearbox changes might be correct, perhaps including gearbox changes even if nothing seemed wrong with the gearbox when it was replaced.
My dad's uncle was a rich bloke, in the 70's or 80's he fancied buying a brand new Rolls Royce but decided not to because the Rolls Royce service plan included changing the gearbox after a certain mileage or vehicle age (I forget which) even if the gearbox seemed perfectly fine, which he thought was 'bloody ridiculous'. Just a GM gearbox but with a Rolls Royce price tag for the unit and Rolls Royce price tag for labour. They were reliable transmissions and could do high mileage anyway, but less likey to fail in a Rolls Royce that had done a certain mileage than in a GM car that had done the same mileage, though only because the Rolls Royce at that mileage probably had the transmission changed at half that mileage or the owner would miss a stamp in the service book lol.
I reckon regardless of how many oil changes a CVT in a 3.5 E52 had during 300000km, if I bought that E52 then used it to tow my caravan / boat over a few hills I'd be worried about not making it to the destination.
For me even if the CVT can last for high mileage with regular fluid changes, if those fluid changes cost (say) £300 every 10000miles I'd be thinking about the CVT costing 3p per mile in servicing costs, £5592 over the 300000km. I would rather have a strong conventional transmission that could go that distance without the regular fluid changes (perhaps no fluid change, perhaps just 1 or 2 fluid changes) and that I could confidently tow with. Especially if the conventional gearbox was also far easier to source and far cheaper to buy 2nd hand and if I'd be far more confident of a 2nd hand replacement not failing again. A good reliable slushbox automatic is one of those components on a vehicle that doesn't need a lot of maintenance and seldom fails, in that respect regarded similar to the diff(s) on a vehicle, I could never think of a CVT in the same way.
There were a few reasons why I got into E51's after a string of Chrysler Grand Voyagers but the main reason was because the Grand Voyagers use an infamously weak gearbox (A604), it is very common knowledge that those gearboxes are weak and the subject is much discussed on many forums all over the internet. I found/suffered the same and have swapped several A604 gearboxes, on one occassion I made one good A604 out of 2 failed ones. I got fed up changing/fixing gearboxes but at least the A604's were plentiful and cheap, available for around £100 from many scrapyards. I knew all the tricks to make those gearboxes last, change their fluid, change their solenoid pack, run 'fill volume learn procedure', fit a second ATF cooler, use 3rd gear when towing instead of 4th, don't spin the wheels (weak diff too and spinning the wheels could see the diff pin fall out) but they still failed. If I'd driven them gently I'm sure they would have lasted longer but towing stuff uphill implies not gently... and other gearboxes were available in other models of vehicle that could handle it all so why take chances with a vehicle that uses the A604. I would have steered away from Grand Voyagers a lot sooner if the gearboxes were not so available and/or cost 40 times more than the £100 to buy. I've done over 100000 miles in my E51 Elgrands including towing heavy stuff 10's of thousands of miles over hills and never had a gearbox problem. Bought my black E51 with less than 80000km on the clock, it has now done over 186000km and I've used it to tow my heavy boat / caravan 10s of thousands of miles, I haven't even changed the ATF on this one yet, will be doing that soon but there are no problems with the gearbox at all.
Just received a parking ticket for using my wife's Dutch disabled badge here in the UK!
What a jobs worth, said I had to have an English version of the badge! WTF, total lies!
Pretend it didn’t happen, enjoy your stay.
Dutch badges are definitely ok on the uk as long as they are part of the “ blue badge” system
Yes, you can use your Dutch blue badge in the UK
because the UK recognizes Blue Badges from EU and EEA countries for visitors. You should display it correctly and it's a good idea to carry supporting documents, such as a translation, in case of any confusion.
  • UK Recognition: The UK accepts Blue Badges from other EU and EEA countries for visitors.
  • Display the Badge: Ensure the badge is displayed correctly to show that you are a visitor with a disability.
  • Carry Supporting Documents: It is recommended to carry supporting documents, like a doctor's note or a translation of the badge, to help local authorities understand your parking needs, as per The Mirror and Car Hire Insurance.
    • Check Local Rules: While your badge is recognized, it is always wise to check for any specific local parking rules in the area you are visiting.
    • I have always used my blue badge in holland and Romania and poland including Germany no problems at all
Should have stuck it on his back as he walked off.
Perhaps they're all in the porn section.
yep dont reply and if they chase it wrong make/model invalid and im sure uk badges are useable in the eu
Unfortunately not necessarily
A Biker friend in Germany had a family member drive an old diesel BMW to London from Germany, use the Dartford Toll, and spend a week driving in and out of ULEZ and CC zone.
He did mot understand how to log onto the websites to pay, so left it, thinking it would be OK.
His tickets, when he WAS tracked down by tfl were over £3K and most had exceeded the pay by and get a discount.
I had to check all the tickets were valid for him, and create a timeline for him to understand the way he was charged.
As a non UK resident he found the signage for payment poor, and vowed never to get caught again...
A possible get out (assuming you establish it is valid and payable) is to return the info saying wrong vehicle details, if 14 days passes before they issue the the correct info, then I reckon you’re in the clear, a ticket in the UK has to be issued correctly within 14 days for it to be enforceable, ignore it would be my option, your money though
