- Cheshireville
- Peter
- North West
Is that a scrotum sac graft Peter?I think I should have read the instructions on the reciprocal saw…..
Saved £80 though.![]()
Their purpose is to catch the 'rocks and pebbles on the initial start-up and few kms. Then it by-passes.What came first the filter or the egg?
They use bigger filters for ride on mowers. Do you think they did it as a joke for the big bad V6 van ?
I have to chuckle every time one arrives.
New ones have flats.Need some new slide bolts for mine, not seized but worn flats on them. I might see what they're like on the scrap Elgrand, maybe calipers too if there's any wear in the holes. Been having some brake judder, sometimes severe but goes away under heavier braking, sometimes no judder at all. Disks, pads, slides and caliper pistons seem OK so I'm thinking it could be the flats on the slide bolts.
Mine have flats and grooves where they shouldn't have lol.New ones have flats.
Much cheapness too…
Newquay I hopeMine have flats and grooves where they shouldn't have lol.
I'm giving it the once over, it's about time because I need it tow the caravan 700 miles soon. Just removed a rear shock from the scrap one thinking I'd previously replaced the drivers side rear shock on the black one but not used the proper bolt, there's been a knock at the rear for a long time that I'm only just getting around to looking at and I was going to swap the complete shock and bottom bolt from the scrap one... But when I came to change the shock it seems I did use the proper bolt and that/the shock all seem good, unlikely to be causing the rattle. There's a split gator on the osr drop link and I suspect the rattle might be that, so I might change the rear drop links if I get time before I go away. Just changing the oil and filter.
Yep, Newquay again....Newquay I hope
You probably know that the flats are to allow the grease to move up and down the calliper bore.
I don't think many people who visit Newquay go around that headland, we usually have a drive around it but walk on a few other headlands such as Porth and the one near Bowgie Inn near Crantock. Reads like you had a good time near the Hue and Cry, did you come away smelling of pilchards?Take a photo of the Hue and Cry behind the Headland Hotel…..ah memories.![]()
No, nothing fishy went on, she wouldn’t let me.I don't think many people who visit Newquay go around that headland, we usually have a drive around it but walk on a few other headlands such as Porth and the one near Bowgie Inn near Crantock. Reads like you had a good time near the Hue and Cry, did you come away smelling of pilchards?
Not since I changed my struts I’m notAnyone else sick to the back teeth of twatting their head on their tailgate? Mike (6’ 1” with a lumpy head).
