- Bristol
- Lee
- South West
Attempted to replace the rear wheel bearing today with little success…
Thankfully I’ve not rounded any bolts or done any damage but I am a little concerned this is going to become a problem if my next two ideas don’t work. I got the hub nut off without issue using my Milwaukee M12 impact wrench after failing to get anywhere using a breaker bar but then was only able to get movement on one of the four bolts holding the bearing on, the other 3 are just not accessible enough with my standard socket and the drive shaft in the way.
After that failed I attempted to remove the whole carrier thingy but couldn’t get the nut on the ball joint to budge so once I’d broken my ratcheting spanner on that and my flexible socket adapter on the bearing bolts I decided to give up and order a stubby 19mm socket and impact swivel adapter in the hope that I can then access the remaining 3 bolts on the bearing and if that fails have another go on the ball joint nut with a new spanner and a length of pipe to get more leverage. Not sure what to do if neither of those things work so fingers crossed!
