- Petersfield, Hampshire
- Chris
- South East
She's back! After driving a 1.5 DCI Qashqai and a 1.2 Spacetourer for two weeks, this feels so rapid now. I've missed the old girl. The colour match is a bit off but, looks like the old one did.
Great news buddy! Colour match looks pretty good to me.
The plastic parts always look slightly different in colour!
Edit: just saw your plate shame the A isn't a U! lol
I won't lie, I scrolled down quickly and had to have a double take on these pics. My brain honestly thought you had a frankfurter on rails for a secondTrial fitting of my DIY rear seat bolt covers, will double up as pull handles in and out of boot etc. Scrapped the cedar idea, sapele much closer colour to dashboard plastic. A little fettling to do and 2 or 3 coats of oil to seal/finishView attachment 100079View attachment 100080View attachment 100081
Bloody big frankfurter, 50mm diaI won't lie, I scrolled down quickly and had to have a double take on these pics. My brain honestly thought you had a frankfurter on rails for a second![]()
Sounds deliciousBloody big frankfurter, 50mm dia![]()
Is that a Nausbamm ramp?Today… wheel swap, build up and fit new suspension…. and machine polish the car ready for Jap Fest…
I would use a volt meter to assess which pin is the 12v, connect that to the positive of the socket and ground the negative side of the socket.Hello.
I've posted a question but it's not showing.
In a nutshell can you use the positive & negative from the heated seat button light to power up a USB socket that I can fit to the back of the front seats?
If so, how do you access them?
ThanksView attachment 100114View attachment 100115
6 wires in the plug.
@LeStempy do you have a wiring diagram or know any idea which I could tap off?
Just having a spot of tiffin whilst awaiting any replies...that will be the next job.I would use a volt meter to assess which pin is the 12v, connect that to the positive of the socket and ground the negative side of the socket.
Might be worth seeing if you can get one with USB-C as well, that's the port mobile phones will use going forward and having one available future proofs you.Seen something like this:-
And hoping to mount it above where the rear remote controls sit, If I can find a path for the cable.
Probably best,Might be worth seeing if you can get one with USB-C as well, that's the port mobile phones will use going forward and having one available future proofs you.
After seeing Blaggards sausage I decided to copy him as I need two tie downs for my mountain bike, I was using tie downs on my Harlequin dance floor but it’s not right for the job.
Is the seat frame grounded already? Might want to test that if it's not known...and ground it to the seat frame.
I have a lazy door, posted about it asking for some advice, worth a read: https://forum.elgrandoc.uk/threads/power-door-struggles-to-open-when-parked-on-a-hill.40846/I have noticed a slow down with my side door electric opening/ closing - i think i start with looking for worn wiring?
Cool, like itAfter seeing Blaggards sausage I decided to copy him as I need two tie downs for my mountain bike, I was using tie downs on my Harlequin dance floor but it’s not right for the job.
Same thing except I used an aluminium pipe, I think it was a washing line at one point and a couple of M6 eyelets.
Covered it in Kevlar wrap ( I used too much heat and it blistered) and job is done.
