Fixed LPG systems on a couple of vehicles you won't be interested in
Dropped the front propshaft off my 2002 4wd Elgrand, been suspecting a problem with a UJ on the front prop for a while because there was an intermittent clicking noise from somewhere under the front that only occurred in certain over-run conditions and could be made to go away by switching from 2wd to 4wd. I let the symptoms develop to make identifying the problem component easier before removing any bits and had to wait until I had time between working on customer vehicles, but today I found time before I had to nip to hospital for an MRI scan. Found the problem before I'd even removed the prop, could make the same clicks by moving the rear of the front prop up and down, the problem is play in the front prop rear UJ.
Front prop removed
To remove the front prop the only other bit I had to remove was the undertray. Difficult to get a socket onto the 14mm hex headed prop bolts/nuts but I managed to get them all off using the ring end of a 14mm spanner and using the spanner on spanner trick to increase leverage. I reckon it too 200ft/lbs to crack the nuts off.
I could now buy new UJ's from BMR and fit them to my existing prop, price of UJ's yet to be confirmed by BMR, or buy a complete front prop from Stevemen for £35 if I collect.
This got rid of the clicking noises but my black 4wd Elgrand is rear wheel drive only now until I've put the front prop back on.
