So a mate turned up, just scored a 52 for may as well be nothing, running when last running parked under a tree with the main battery fuse blown, he did the right thing and took it for a warrant, it failed so you have x amount of days to sort that get a recheck and pass before you have to start all over again by paying for a new go, two major clues here to the happenings already. he failed on you guessed it, the piece of copper pipe hammered flat and jammed in where the main fuse on the battery was supposed to be. n0 park lights, no low beams HIDs, no horn. Assorted cracked and broken driving park stop etc plastic. Loose front bumper, no glass drivers wing mirror and all four corners for the brakes not just pads not a hose, all of the brakes components along with a sigh off sheet for the mechanic to declare what he did and where he brought the parts from, which parts, the whole nine yards, ready set go, lets start with the park lights, good fuse, power yup,no power at the light, lets work our way back toward the feed till we find were it is evaporating. it didn't go to its proper home instead it went to a aftermarket button to do with clarion stereos by the steering wheel, there is another feed coming off of the same switch where do that go I do not know. were to it come fro0m , down by the middle stero ways. i started the car and turned on that random switch Park Lights fixed. so main fuse blown parklights wired the sterio power but the proper power still works from the magic power box. horn that was a relay in the magic battery box, fixed. back up shit the fog lamp bulbs just evaporated. pause think thats ok they have already passed so they wont look again because a recheck only involves the original fails. next is the headlights and the power and switchs all do the right thing but the HID bulbs only flash for an instant, is that the bulbs or the ballast, the 12v feed power dont drop any worrisome amount upon initial startup so its not a draw issue on the supply second battery hooked up so as to ensure im not setting myself up there. removed the bulbs for the mate to get tested. im feeling energetic so its time to totally rebuild the brakes, cleaned, honed bores, all seals and dust covers replaced, pins lubed and new pads all round, sanded the shit of off the handbrake shoes and bleed new fluid through the hole system. fixed. spent a bunch of time putting the dash back together as i had tried to find where that headlight power went and the other new power came from. fixed, but still dont know. started fixing the plastic on and around the tail lights with clear perpex and hot glue sticks melted with a lighter fixed followed by frankenstien stiching the front guard together with cable ties, fixed. double sided tape behind a flat piece of mirror glass sticking it into the wing mirror its in there and most probally will stay in. fixed its now 930 pm and the recheck is the nerxt day a mate pulls up the drive with HIDS on his car, lets go, great time to finally find out that the bulbs and ballest have left the building, bugger me. its morning time and old mate dont have much time or 180ish for each bulb let alone enough children to sell for two new ballasts, thinking...thinking... last chance is to try and jam some sort of 12v LED in the hole and power it from the origanil 12v low beem feed which means the origi8nal switches will be used. so the cheepest non brand LEDs fit in the HID socket but it does take a lot of time and Skin to get the clips to seat properly so they dont bounce around. ouch. time is running out, I slapped up a couple of adapting wires to mate factory plugs to LEDs taped everything up. fixed. but hold on thats a LED bulb in a HID head light no way is it bright enough or possibly in the correct position to focus in the same place as before they are going to fail. 2 hours to go. old mate drove off to the testing station i went home and cursed myself for not pushing for the bulb test to happen sooner. bugger it . so everything passed the low beams even focused the light in the correct place on the headlight test board, what have you done to your Elgrand today,
