- Mid Yorkshire
- Simon
- Yorkshire
On that note, would anyone mind telling me whether the rear spring height adjusters go at the top or bottom of the spring? First time fitting coilovers and they’re second hand so no install instructions!Decided I’d set out to swap in coilovers this weekend. Am a novice and it’s definitely taken me longer than expected, still halfway through doing the rears!
Is it the weekend for fitting coilovers?! lolFinally managed to get the coilovers halfway on this afternoon… thought I was fitting a sofa with how long the rears took!If anyone’s got a trick for the spring height adjusters without losing a finger, holler. Other than that, she’s just been sat there looking pretty and mocking my DIY skills.
Rear spring adjusters go to the top ( won’t be able to adjust them at the bottom)Finally managed to get the coilovers halfway on this afternoon… thought I was fitting a sofa with how long the rears took!If anyone’s got a trick for the spring height adjusters without losing a finger, holler. Other than that, she’s just been sat there looking pretty and mocking my DIY skills.
Nice one! Does this usually go on or replace the rubber mount at the top? They’re Teins if it matters. Asking for tomorrow, the rain and dark have given me a good excuse to leave it for today!Rear spring adjusters go to the top ( won’t be able to adjust them at the bottom)
There is usually a shim between the spring and collar if not , try to get some , grease these to make adjustment easier
The original rubber cone comes off ( single bolt up through it’s centre “deep”)Nice one! Does this usually go on or replace the rubber mount at the top? They’re Teins if it matters. Asking for tomorrow, the rain and dark have given me a good excuse to leave it for today!
You may or may not have a thinner rubber or plastic replacement in the setup you have ,the bottom of the spring will normally use the original rubber seat unless one is supplied ( make sure the spring end is in the stop position of the rubber seat to prevent the spring turning)
My nipple dropped off! 17 years! just over 17 days, I thought one hadn't soldered properly, ripped the panel and pulled cable out but ran out of daylight, I'll sort it tomorrow.Refitted the offside sliding door cables and motor, both doors should hopefully should be good for the next 17 years.
Blimey, I like to put my foot down often once the engine is warm for a bit of fun and I get always between 7.5km/l - 8km/l. Mine is only the 2.5L engine but you must be holding that thing down lolFilled up last night and manually worked out my mpg between fills... 12.95mpg
Which I think means the onboard computer reading of around 4.5 km/l since I got the car is probably about right. Guess I need to take the lead out of my right boot lol
The only way I can get mine over 5km/l is to reset the computer at the top of a long hill. It doesn't stay that way long though. Maybe something to do with it being the 3.5 Rider high performance version.Blimey, I like to put my foot down often once the engine is warm for a bit of fun and I get always between 7.5km/l - 8km/l. Mine is only the 2.5L engine but you must be holding that thing down lol
Mine suddenly went two days ago, I let it go as usual, walked forward and bang. I was considering SGS but now I think I'll pay a little extra. I don't want to repeat that in a hurry.Fitted the tailgate struts from JDM Car Parts... No more sagging tailgate or clouting my head, result. SGS ones in the bin...
Also replaced the bulbs in the tailgate panel which wasn't too hard despite sausage fingers.
Noticed an annoying belt or pulley noise when starting the car this morning in the cold and damp... Hey ho, the quest for a fault-free car continues...
