"Tractor" diary. Elgrand from Siberia. E50.
Merry Christmas, friends!
I'd like to say how delighted I am to be here in this virtual circle of like-minded people. You're all absolutely awesome, just like your cars!
I wish you and your families strong Siberian health, new goals, and the achievement of them.
Travel, discover new things, and explore this world.
To your buses, I wish smooth roads and freedom from rust!
Happy Christmas holidays, friends!
Merry Christmas Boris, have a good holiday
All the best mate
Thanks for the thought but between the potholes, speed bumps and utility workmen who can't refill their trenches flat with the original surface we don't stand a chance in the UK.
Happy holidays to you and your family! Must be chilly in siberia at the moment.
We are just coming to summer in nz.
Santa hats and bikinis :) not the same as white Christmas season at all.
Awesome thread. Iv got a qq60 td42t, and couple of qd31eti. They dont build them like this anymore so im hoarding them.
Keep up the good work
Happy New Year when it comes to you and yours :)
Ho-ho-ho, frosty greetings
From 31.12 to 12.01 there were New Year's holidays.
I tested a new barbecue (the barbecue project is still in progress, the main thing is that the base and firebox are laid out, this year I will finish the barbecue area and the campfire area)
We went skiing.
Grandfather Frost (Santa Claus for you) gave me an electronic drum kit, now we're playing rock.
Throughout the holidays, the tractor did not fail.
The real Siberian winter has arrived today. - 46.
In the morning, I started the car in the garage - it worked for 20 minutes. To move around the city in a dense stream in such a cold, I turn off the 4th gear (overdrive), this allows me to keep the engine within 1000 - 1500 rpm, at such speeds the heaters are blowing hot. In a traffic jam and when driving in traffic jams, I either turn on the 1st gear, or turn on the winter mode (winter) and switch to the 2nd gear, thus moving within 100 - 1500 rpm at the speed of flow. In general, the Winter mode is always on while it is winter and icy.
A couple of golden rules of a diesel driver in the cold:
1. I ask myself the question, why did you buy a diesel engine?
2. I answer that diesel is the fuel of the Gods, and the entire modern civilization was built and is being built thanks to diesel.
3. Before starting the engine, I warm up the glow plugs 3 times (I wait until the glow switch turns off, although the spiral goes out after a couple of seconds, but the relay works for 15 seconds)
4. There should be at least half of the fuel in the tank.
Do you heat the diesel and filters, or use any additives etc in the diesel? Ever need to use ether to help it start?
No need for a freezer with those temperatures outside, could keep frozen food for the barbeque just in a box?
Years ago I went sea fishing with my dad, we caught too many fish to keep in the freezer but it was snowy and freezing outside so we put the fish in plastic bags and left them outside buried in snow. Didn't quite work as well as we hoped, our garden became very popular with seagulls lol.
Do you heat the diesel and filters, or use any additives etc in the diesel? - I don't use heaters—the car stays in the garage overnight.Fuel additives—I've used the HiGear additive a couple of times, but I've been doing without them for several years.
No need for a freezer with those temperatures outside, could keep frozen food for the barbeque just in a box? - Once upon a time, in the 90s, when food was really tight, my parents would buy a piece of a cow. We would cut up the meat and put it in bags and 200-liter barrels. We'd cover the barrels with snow. But keep in mind that our winters are cold. We'd take the bags out as needed.Life is different now—I have a separate, large freezer.
I wouldn't risk storing food in the snow—rats, eagles, and other predators are a threat.
Is this the end?
I started the tractor this evening. The RPMs skyrocketed. I turned the ignition off, but the tractor kept revving. I quickly realized the engine was running wild. I took the sleeve of my down jacket and wrote on the air duct. The engine gradually slowed and stalled. There's a lot of oil in the intake tract, the turbo... I'll start looking into it tomorrow.
He's alive!!
Hi.Today I started figuring things out. I removed the choke assembly from the intake manifold. I removed the air lines from the turbo. I added 2.5 liters of oil (the engine consumed 2.5 liters of oil in 1 minute at high RPMs). With a capacity of almost 7 liters, I believe the engine wasn't starved of oil. I removed the glow plugs (the plugs on cylinders 2 and 3 were burned out).
I poured diesel fuel into the glow plug area, waited, and started cranking the engine (with the fuel supply turned off).
I repeated this procedure for about 20 minutes to clear the cylinders of oil.
I checked the compression: cylinder 1 - 30, 2 - 32, 3 - 30, 4 - 31. Excellent result.
The engine turns over easily, without any unnecessary noise.I took glow plugs from the spares and screwed them in. I started the engine without air flow from the turbo. Started up fine. RPMs held steady.
A geyser of oil was coming out of the turbo hose.
I'm concluding that the turbo and glow plugs need replacing.
It was a minor scare.
A small video bonus
He's alive!!
A small video bonus
I’ve used a turbo refurb kit on a Delica 4M40 Td4 it lasted for 80,000 miles.
Much cheapness too.
If I did it again I would buy the cartridge- less faff.
Turbo, hello!
I removed the intake manifold (there was an incredible amount of oil carbon deposits) and soaked it in gasoline.
I took the turbo-killer to a specialized service center that repairs and diagnoses turbos. I decided to buy a new one, but I wanted to know the reason for this madness.
I chose the most luxurious service center, an official Land Rover dealer. Yes, because of the sanctions, the service center started repairing turbos.
So, I go to the dealer. They have new Range Rovers and some other Rovers, very beautiful and very expensive.. The price starts at 20,000,000 rubles (that's f*cking expensive, just for a car). I wouldn't use that to transport plywood, boards, or bags of cement.
I was met by a guy in a nice jacket and a pristine white shirt. I handed him the oil bag with my turbo. Waited 20 minutes, walked around the showroom, looked at the new Range Rovers, didn't sit in the cars, dressed too casually – not proper.
I also noticed a large number of Chinese luxury cars, like Zeeker or Zinger, but they were big, very expensive, and battery-powered. I didn't touch some kind of miracle electric vibrator, in case it was contagious.
Then a guy came out with a box, and in the box was a disassembled turbo-killer. As a result, something from the exhaust had gotten into the hot section of the turbocharger, breaking the blades, causing an imbalance, and oil was leaking into the intake. I asked if they could fix the turbocharger, and they said, "Your turbocharger is too old and there are no good parts. They don't install Chinese parts."
So, I received a new Chinese turbocharger. New glow plugs. Everything was disassembled. I'm gradually cleaning out the oil.
