The Boss
North East
Likes
7,527
Hartlepool
E-Bucks
3041
E50
North East
Thanks - and Ouch! that's quite the price - haven't looked under the car yet but assuming I'd need 2 of these?
Just remove them, cut them open, smash the cores out, weld up, and re-fit. That's what most people do.
Chris T
Part of the furniture
Wales
Likes
4,030
South Wales
E-Bucks
1266
Chris
Wales
Both pipes you need are in that kit. It's expensive and maybe a local exhaust place could make it up cheaper, but if you're looking to take it to a garage it will probably be cheaper and easier to get the garage to decore.
The advantage with those replacement pipes is someone with minimum tools and skill can swap them in their drive.
BigAndy1979
South West
Likes
35
West Sussex
E-Bucks
0
Andy
South West
yep, going for the cheaper option of de-cating, booked in for next week.
Have a good Powerflow exhaust place in Hove that done my Merc 190E Cosworth about 12 years ago so if I was going to spend £££'s would probably opt for them to do it. I just want rid of the potential problem rather than any BHP/sound gains.
Phil
Likes
5,613
Shropshire
E-Bucks
2297
Phil
the only advantage of the kit is that you know for definite that the cats have been done. I'm not saying all garage services are dodgy but I wonder how many people are running around thinking their rear cats have been decored when they haven't?
Edit. And they are easy diy for the occasional home mechanic. So that's 2 advantages then :)
Archies Gang
Scotland
Likes
28
Scotland
E-Bucks
20
Bruce
Scotland
Just carried out a secondary cat decore on Snow White today was so :worried: about this issue.
off side cat not a problem(Long pipe side) cut open as describe in the forums and re-welded:D
sheared 2 of the studs on the offside cat :oops: had to drill out:relieved: and fit 2 bolts.
to save cutting and welding this side is it is easy to smash the core out :grinning:
Now Snow White is singing a sweet song and now i can rest happy it ain't gonna go bang :D
Highway Dave
Yorkshire
Likes
1,310
south yorkshire
E-Bucks
1317
Dave
Yorkshire
OK ,so just took the heat shields off (lifted them to gain access)---nothing apparent on the short one but what feels like a line of weld (very smooth if so) on the longer one, so i'm really no wiser as they both sound the same if I tap with a spanner (not dull but don't ring out so to speak--in fact i'd say they sound like hitting a normal section of exhaust--I suppose i'm going to have to have them looked at
two questions first
1; my elgand E51 2.5 has over 92 k in miles (would cats have gone before this ???
2; Is it as big a problem with the 2.5 as it is with the 3.5 given the differences between the two engines build wise and compression wise etc
The Boss
North East
Likes
7,527
Hartlepool
E-Bucks
3041
E50
North East
@Highway Dave - the engine makes no difference. The problem is relevant to any car with pre and post cats in an exhaust system.
If they sound hollow, then chances are they have been done. I would remove the easier of the two pipes (the straight one) and have a look. If it's clear, and it makes the same sound when you hit it as the other one, then they have both been done.
For peace of mind, you could check the other one by sticking a length of hose pipe through it. If it goes all the way through, then there is nothing in there.
E51ZRider
Club Rep - South East
South East
Likes
2,111
Windsor
E-Bucks
1759
Peter
South East
Edit =- just realised it's for both pipes, so not so much ouch!
I have those on mine and its peace of mind.,..any issued rebolt cats for MOT...
Highway Dave
Yorkshire
Likes
1,310
south yorkshire
E-Bucks
1317
Dave
Yorkshire
I know what your saying mate and I know it makes sense-----it's just that if I take the exhaust off myself I just know i'm going to end up putting something else back on ,i'e stainless---not because they need it, just because lol
The Boss
North East
Likes
7,527
Hartlepool
E-Bucks
3041
E50
North East
More reason to do it ;)
skyrider
East Anglia
Likes
27
felixstowe
E-Bucks
63
geoffrey
East Anglia
if you have your cats replaced keep the old ones and have them clean out in your own time then if your Elgrand fail the mot because they are missing you can put them back on
GNDTECH
Likes
1
Grenada
E-Bucks
0
Garvey
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
The PRIMARY cats are the problem. Through use, after heating up and cooling down, they start to deteriorate. This happens with ANY catalytic converter when they reach the end of the their life. As the PRIMARY cats starts to break down and fall apart, the debris is pushed back through the exhaust. At this point, they come into contact with the SECONDARY cats, which creates a blockage.
There are 2 main options.
1/ DECORE the SECONDARY CATS. This is a simple process. You remove the secondary cats, cut an opening in the top, smash the internals out, weld the opening shut again and re-fit them. This removes the point at which the debris from the PRIMARY cats will get stuck creating a blockage. The debris is just pushed out the back of the exhaust.
2/ Remove the SECONDARY CATS. Same principle as option 1, but you remove the cats altogether and replace with a straight through pipe. This is more costly than option 1, BUT what it means is that when it comes to MOT time, you still have the cats to fit to the vehicle if there are ever any issues.
But what about.......?
Is this legal?
Why does this need doing?
Spend the 400
Highway Dave
Yorkshire
Likes
1,310
south yorkshire
E-Bucks
1317
Dave
Yorkshire
@Highway Dave -
Wow---just realised what you said karl-----not only are the Elgrands good looking,powerfull,quick(going on fast),reliable etc etc, but now you tell me they can also take a length of hosepipe without ill effect------thinking seriousely of sacking her indoors now :):rolleyes:
Chris T
Wales
Likes
4,030
South Wales
E-Bucks
1266
Chris
Wales
Hi there,
Was the £90 to remove both rear cats, cut open the top remove the insides and re-weld?
My 2003 E51 done about 88000kms so maybe I should have the job done.
regards
jackh
There's no maybe, have it done mate, they will fail in the end. We've had a member today have a lucky escape due to partially blocked cats. It's not worth the risk at all for £100.
