Project "Member Map" in progress
The amount of people I get asking "have you got any members near X" or, "how many people live near Y" is astounding. So to help with this, I have started project "Member Map".
LINK TO MEMBER MAP
This map is now an automatic system that adds ANY members with more than 10 posts.
The locator is based on IP GeoTagging, so the pin will be "roughly" where you are, but not precise.
This means that your location is not specific, but a good indication which will help people arranging meets etc in your area.
YOUR PIN MAY BE IN THE WRONG PLACE AS THE LOCATION IS BASED ON YOUR IP ADDRESS
  1. Find your Pin
  2. If it is in the correct location, please move it slightly so that it remembers where you drop the pin, it will not move from where you drop it.
  3. If your pin is in the WRONG location, please locate it and drag it to the correct place, it will not move from where you drop it.
  4. If you are in the correct place but you DO NOT MOVE THE PIN, then you will find your pin moves if you log on with another device.
If you do NOT want to be on the map, you can OPT-OUT. To do this, click the link above, find your pin and click the "opt out" check box, your pin will then be removed.
GDPR DISCLAIMER
By signing up as a Member of ElgrandOC, and actively partaking in the forum:
I agree for my personal data, provided via IP based GeoTagging to be processed by ElgrandOC.
I agree for my personal data, provided via map API calls, to be processed by the API provider, for the purposes of geocoding (converting addresses to coordinates).
When using the User Generated Marker addon, data will be stored indefinitiely for the following purpose(s):
  • To allow other members of ElgrandOC to locate me on a map
  • To allow event organisers to find local members for events, and agreeing to allow them to contact me via the forum to include me in said events.
  • To allow the ElgrandOC administration to generate statistics based on geographical information given.
Whoop whoop, I've managed to update my location, if any members are in the area, feel free to visit
LINK TO MEMBER MAP
  1. Find your Pin
GDPR DISCLAIMER
This is great, I've never been part of an OC before, never had a worthy vehicle before. It's inspiring!
Can't find my pin anywhere. My ip im in sale, manchester but my ip address from brsk is london. But cant my pin in either
it shows nothing for my way
just checked preferences and im not opted out - likewise, im not shown in SE London \ Kent, in fact no one appears...
Privacy options
  • Opt out of the Member Map
Yep I wanna opt in. . should I see my location on the map
And I'm not ticked for opt out
As I just wrote above, I found myself in Cornwall. I live in Cumbria. Just keep hovering over the balloons on the map, until you see your username.
