Hi can i get in touch with keith please i need a disc
You can source one here https://www.caraudioworkshop.co.nz/e51e52elgrand if need be.Hi can i get in touch with keith please i need a disc
£300 is a bit steep, is that the only option? Thank you for the fast responseYou can source one here https://www.caraudioworkshop.co.nz/e51e52elgrand if need be.
It's 300 NZ Dollars so about £130.£300 is a bit steep, is that the only option? Thank you for the fast response
How can I get conversion cdGot the language conversion cd for my S3 from Keith at Elgrand Campers, well worth doing & makes things a lot easier to navigate through.
Can I get Keith's number for the conversion cd I am desperate.Thank to Keith for sorting me out with the English cd. If you need to find Keith cowie. Try to pm him on Facebook at Deerside Elgrands. Hope this helps
Sent on your PMCan I get Keith's number for the conversion cd I am desperate.
What's the cost for the conversion cd?
Read here https://www.caraudioworkshop.co.nz/e51e52elgrand. You can buy the file and burn your own CD or use flash card.Sound thanks for that ,does it convert everything on the display?
PM sentHello anyone have Keith number need a cd
PM sentPlease could also have Keith’s number for a conversion CD.![]()
