Cruise control
V6Grandad
North East
Billingham
Alan
North East
When searching for an Elgrand I noticed that cruise control, which I wanted is not a popular option. The XL I finally bought has radar cruise which I believe is rare, it just seemed strange with Elgr@nds coming with,twin sunroof,twin power doors etc.
I have an XL and it dosnt have cruise.
Not sure if i ve got one:( will check in the morning!!
It was never standard equipment, even on an XL. Only fitted as an option. It will only let you set it to a max of 110km/h because the speed limit is 100km/h in Japan, which means that due to mandated speedo error you get about 65mph max. I expect it is more likely to be on an XL, as they would perhaps be bought by someone who wants all the extras.
Several members (not me!) have successfully fisted after market cruise controls. I'm sure there'll be a project thread on here somewhere. Just put cruise control in the search or someone may be along soon to give more info.
I have fitted a cam8 cruise control. Works well. There are other makes available. Fairly simple to fit.
Thanks the replies, as regards the speed limiter, I didnt know about that so thanks for that one, I’ll try it above 110kmh and see what happens. Regards Alan
Bannings in Guildford fitted my cruise control a couple of years ago, it's a stalk type postioned left of the steering wheel, works fine and was'nt that expensive. I looked at getting the OEM version fitted into the steering wheel, only place I could find one was on Ebay from Australia and the price then was about A$600 not including postage!!! not for me.
As Ian and maybe others have said, the factory fitted cruise won't let you set a speed above around 110kph.
One of my Elgrands (I own 2) has the factory cruise. I need to look at it because it tends to work for a few minutes then beeps and shuts off with a Japanese warning message on screen, if memory serves the warning message points to something about the sun affecting the radar but it happens at any time (even when it's dull etc).
I've bought the canm8 one, but haven't had a chance to fit it yet.
Very helpful folk too.
Really really miss having it as I've had it on every car I've had for about the past 20 years and used it all the time.
Even more useful these days with all the smart M'ways & long stretches of average cam works etc.
Quite useful info for me here as i was looking to fit after market cruise control for quite some time but wern't sure. Thanks all
Does anyone know if the e50 had a cruise control option. Looking at buying one and never seem to see it listed
Hi Ian,
Spent a bit of time trawling around, and you gave me the answer that the cruise control on my E52 is limited to 110kph. Can I ask, if you know whether that can be overridden somehow ?
Thanks in advance.
Regards,
Martin.
Hi Ian,
Thanks in advance.
Regards,
Martin.
Unfortunately I don't. I was wondering if using a chip to convert the speedo to mph would result mean that the cruise control would be limited to 110 mph, but I am not sure it uses the same feed.
oooo, I like your thought process there. haha Anyway, thanks very much. I'll keep digging, maybe my local Nissan garage would know. cheers
I definitely would not fit a chip to it there was a guy on here had problems cost him a fortune and over a month to get it sorted found out that it was the speedo chip which was causing all the problems
Quite possible, there could be several things on the car that need to know the speed in kph - might through the gearbox out if it thinks the car is going more slowly than it is.
