- West Midlands
- David
- Midlands
I've had my 3.5 Rider S Autech about 6 weeks now and been dipping every week but nothings changed.I suppose I'm fortunate that my Ellie doesn't use a drop of oil.. checked it before my run up to Wales, the Scotland and back down South... 1300 miles clocked up in a week... not a drop usedwish it was the same for the fuel
Do you check when the car is 'cold', as in after overnight standing? I find this is better with other cars as it's easy to see on the dipstick when not hot and smeared every where, and compare to previous- you're comparing it cold to how it was before, cold. Is this method okay on the E51?
It's fine checking cold - basically as long as the oil has drained down from the engine, you're fine. The manual states to leave it at least 10 minutes after switching off.Do you check when the car is 'cold', as in after overnight standing? I find this is better with other cars as it's easy to see on the dipstick when not hot and smeared every where, and compare to previous- you're comparing it cold to how it was before, cold. Is this method okay on the E51?
There’s not much in it from hot to cold but ideally you should run the engine to get the oil to temp then let it drain for ten minutes and check the levelDo you check when the car is 'cold', as in after overnight standing? I find this is better with other cars as it's easy to see on the dipstick when not hot and smeared every where, and compare to previous- you're comparing it cold to how it was before, cold. Is this method okay on the E51?
These are fussy, sometimes unique engines but as long as the cats aren't scouring the engine and the oil is changed regularly, they are very reliable. Mine will use about half a litre every 1000km used daily, more if driven hard, less if I'm gentle.Hello everyone,
I’ve started driving my Elgrand daily instead of the odd drive on weekends & i’ve noticed its using alot of engine oil. Had a full service around 8 months ago (done around 5000 km since) and thought I’d just check oil level before a long journey. It wasn’t showing anything on dip stick. I topped up with one litre.
Checked again after around a couple of months (1500 km) and it wasn’t showing anything on dipstick. I topped up with around 3 litres and it was showing towards high level on stick. Checked after driving 600km and it’s showing towards low level on stick.
Everything runs fine and its not smoking or making noise. Any ideas on what could be causing this? Surely this isn’t normal!
Its not smoking and everything seems to be running well. Your right about the level, i’ve just checked again after around 400km and it doesn’t seem to have moved from the last time I check when it was showing on low level.These are fussy, sometimes unique engines but as long as the cats aren't scouring the engine and the oil is changed regularly, they are very reliable. Mine will use about half a litre every 1000km used daily, more if driven hard, less if I'm gentle.
Another thing to consider is that the level is strange anyway. It can show from nothing to full in what seems less than a litre of oil.
Others will advise better than me though...
It's recommended to check more than every two months. Try every week instead.
Does yours smoke on start-up?
And this oil is pretty expensive. But don’t want to damage engine with cheaper oil, that will be expensive to repair!!Just an update on my Elgrand engine oil consumption.
Its using around 1 litre of oil every 1000km
Would be nice to know what others use?
Any oil someone could recommend please? Ive been using; Castrol Edge 5W-30 LL Engine Oil Fully Synthetic with Hyspec Standard, 4 Litre
when i worked for a Suzuki dealer (motorcycles) i had a few customers complain about some bikes using oil, I spoke to Suzuki technical UK and they said if it uses 1L or less in a 1000 miles then its acceptable and no warranty given !!!!!Just an update on my Elgrand engine oil consumption.
I think @Londonglide didI can get 20litre for £38 on ebay which seems really cheap. Anyone used this?
20L Mannol ENERGY 5w30 Fully Synthetic Engine Oil SL/CF ACEA A3/B4 WSS-M2C913-B
