I can't answer you but was wondering the same for an E51 ... presuming it would have to be a tow bar fitting one but would be good to know if anyone has got one for either model they recommend!Hi all, after a bike rack for my E50, what have people fitted ? Is there any difference between the models asto which rack will fit ? Cheers.
PS just realised this is in the 'social' section so maybe try in the 'technical' section too? I have tried to search but can't find anything conclusive!Hi all, after a bike rack for my E50, what have people fitted ? Is there any difference between the models asto which rack will fit ? Cheers.
@AlanM is your man for bike racks.I can't answer you but was wondering the same for an E51 ... presuming it would have to be a tow bar fitting one but would be good to know if anyone has got one for either model they recommend!
I have the Thule 973 with fitting kit 18 on my E51 S1 with the standard rear spoiler.@AlanM is your man for bike racks.
There is a thread here which goes into more detail about the bottom lip issue when fitting the Thule 973 rack (with photos):I have the Thule 973 with fitting kit 18 on my E51 S1 with the standard rear spoiler.
This rack doesn't fit some E51 that have extended spoilers and some boot bottom lips can get in the way of the rack's bottom fixing clips.
Thanks, Alan - i don't think the one I've got a deposit on has these extensions so hopefully will work - I'll look into weight restrictions as we both have an electric bike and they're about 25kg each. My bike is a step through so I see there's another mention below about an adapter needed.I have the Thule 973 with fitting kit 18 on my E51 S1 with the standard rear spoiler.
very helpful - thanks!There is a thread here which goes into more detail about the bottom lip issue when fitting the Thule 973 rack (with photos):
Me too - a step through Moustache 28.3 - my other half has a Trek e bike so at least 50kg between us - I won't get my camper conversion until early Feb so I'd be really grateful if you'd update me if you go for the Atera genio pro or Buzz Rack if they work with the tailgateI have an e-bike, it's a step through so does'nt have a cross bar and needs a sturdy rack coz it's heavy !
Thank you soooo much - that’s really helpful indeed - much appreciated!!!Hi @erichmond - a few points for your consideration regarding the Thule 973 (Thule also refer to this model as the BackPac):
Bike Frame Adapter (for step-thru frames) - Thule item# 982 - typically priced around £25 plus p&p
- you can find an instruction manual for this rack here
- in these instructions you will see that the rack alone weighs 15Kg
- although the Nissan Elgrand isn't specifically listed, other Nissans are and the instructions indicate each bike carried should be no more than 15kg with a maximum of 3 bikes allowed at a total bike weight of 45Kg.
- I have personally carried my wife's eBike at 21Kg on the innermost position plus my 12Kg steel framed bike in position two without any apparent damage to the rack or Elgrand, but there again I haven't dropped down any large pot holes whilst so loaded either, and it is in such situations that any overloading might make itsself known!
- Removing the ebike batteries before loading is the obvious thing to do here and makes the lifting of the bikes into position easier anyway
- this adapter connects between the handlebar stem and seat post on a step-through bike frame to allow the rack's securing arms to hold the frame securely
- as indicated in the pics below, the rack's securing arm head swivels and I have used the arm, without the frame adapater, to hold the wife's bike directly on the handlebar stem (indicated by red 'X' in the pic). To be able to do this is going to be bike layout dependant.
I'm now looking at the same, did you ever work out whether the tailgate could lift with the different buzz rack carriers?I'Ve been looking at tow ball mounting bike racks, RoofBox.co.uk do a good range of racks, I was thinking of Atera genio pro gives enough tilt to allow tailgate to open, Buzz Rack E-Hornet is cheaper, it tilts but might not give enough clearance for tail gate to lift, check them out.
What rack is this please
Un8versal amazon job 30 quidWhat rack is this please
