- Somerset
- Kevin
- South West
I am looking to get a set of new wheels for the Audi Q3 that I have recently bought my wife and have seen a nice set of Work split rims that I like that are 19x9 but are a 5x114.3 pdc (same as the Elgrand) with a 38 offset where as the Audi is a 112 pdc
Due to a combination of the width of the wheel and the offset it seems that if I fit 5x112 spacer adapters to fit to the 113.4 wheels which it seems I can only get in a minimum of 20mm this is going to be right on the edge of fitting and will potentially rub on the outside wing
Without the adapter spacers they should fit fine.
To get around this I could fit wobble nuts rather than the adapters but am a bit dubious of them.
Any one used wobble nuts and thoughts on them please.
Edited to add that I have now found 15mm adapter spacers but this looks like it is still going to be really tight so would still welcome any thoughts on wobble nuts
