- Sunderland
- Colin
- North East
Prompted by this thread by @japrider back in July. I've been meaning to check but kept forgetting.
After hosing Magnu down to remove the Sahara sand I opened the bonnet to top up the windscreen wash and valve saver fluid.
There was a small amount of water in various places. I only used a heavy jet on a bird poo strike on the passenger side of the windscreen for the rest I used a moderate shower sprinkle.
I've got some Tiger mastic stuff tucked away to use around the rubbers.
Water got under the rubber, and may have gone over as well, on the passenger side.
It also got under on the driver side.
There seems to be a missing bolt here and water went through the hole.
Possibly another missing bolt but it was dry underneath. The square holes in this and the other pictures are above a metal panel which I'm guessing is a drainage channel.
