Stereo
Dowd
Midlands
B263la
Mark
Midlands
I’ve got an Elgrand e51 series 2 I want to change the stereo to a double din one anything I should know thanks in advance
Just that it's not particularly hard, so don't worry. You get pretty immediate results as the new stereo will fire up and play through the speakers once the ISO harness is plugged in. The trickiest part is adding all of the other ancillary wires that you might be using and running them around the van under the various trims (DAB aerial, microphone, USB extensions etc).
What stereo setup have you got? It gets trickier with the Bose stereo and even trickier with the Nissan 5.1 Surround stereo (dash centre speaker with no branding on).
Basic Kit List:
- Double DIN
- Nissan Micra ISO harness
- S2 fascia panel
- Tools: Plastic levers, screwdrivers
Optional Extras:
- DAB aerial
- Phono cable to take video to rear inputs and allow video to be played from head unit to rear screen
- Extra USB ports to wire in while you've got everything out
You need to ground the wiring adapter to the chassis as the Elgrand loom doesn't have a ground.
Good point, and the 'parking brake' cable from the head unit if it has one.
Also, you may end up with some unused wiring from the old stereo left in the dash and this is fine. I think I had an unused connector from the DVD unit, the FM aerial which I didn't reuse and one other single cable that I didn't pay attention to what it was, but it definitely wasn't needed for the new unit.
The only bit on mine that required some actually wiring in as opposed to being plug and play was the steering wheel controls, which had to be cut out of the otherwise unused DVD connector.
There is an 8pin DIN connector that routes the audio from the VTR input into the factory stereo. If you want to listen/watch this on the front screen you'll need to wire this to the Aux in on your new stereo.
This will be my next task. Im guessing if my speakers dont say bose on it its the standard speakers. If so gonna get facia and a double din, and may invest in upgrading the speakers if its not upto it.
Yes, but if you have a speaker in the middle of the dash then it's 5.1 DTS so the best bet would be to trade in for another Elgrand.....
Double din fitted 1 year best thing ever done
