- Mid Yorkshire
- Simon
- Yorkshire
A few observations having had LPG conversion 5 months ago;
MPG 18 - about 10% less than petrol which is par for the course. Petrol is used during initial heating up so you will still need to buy small amounts.
Some outlets are a bit awkward to get in and out of.
70 litre tank is quite deep - exhaust silencer is lower but you still have to be careful not to scrape it if driving onto a lower verge, etc.
Fuel gauge (series of LED lights) is hopeless - you get used to resetting trip meter and looking for refill after 200km.
The installer didn't replace the plastic engine cover - apparently since the engine can run hotter - the increased noise is noticeable so I am looking at sound deadening to stick under the bonnet.
The filler cap is not attached to the vehicle on a wire, etc, so you need to remember to replace it.
On mine the filler cap is in the rear bumper - not ideal if you have a bad back.
I didn't fit your conversion but...
I fit a 93 litre tank that is no deeper than your 70 litre tank, it is wider not deeper, I angle it so it is 'deeper' toward the front but no lower than the diff, which means there is more ground clearance at the rear than on yours.
Sounds an un-neat job if the installer didn't refit the engine cover.
99% of my 700+ Elgrand customers chose to have a hidden filler fitted, hidden behind the petrol fuel door, no holes made in the bodywork or bumpers and no chance of losing any cap.
200km is only 124 miles which woul be pitiful range. The 93 litre tanks I fit hold 84 litres of LPG because I modify them to fill to 90% of rated (93L, 18.48 UK gallons) capacity instead of 80% of 70L capacity. Which even at only 18mpg gives over 330 miles (over 500km) of range if driving steady on a long motorway trip. I fitted a 2nd LPG tank that is easily detachable / refittable using quick fit fittings... and doubles on board LPG capacity and range when fitted I can drive 700 miles on LPG with my 2nd tank fitted. I've also set up the same system for a few of my Elgrand LPG conversion customers but only for my conversion customers or people who have bought a vehicle that I converted to LPG originally.
Then we can talk about how soon after starting the engine on a cold morning the system switches to LPG (obviously affecting the ratio of petrol to LPG you use) and how correct mixture on all 6 cylinders is better than a bit richer mixture on some cylinders than others (affecting efficiency and engine life) during average driving and how correct mixture when you put your foot down is far better than too lean or too rich mixture when you put your foot down (affecting efficiency and engine life and max engine power). Life of the system (with accurate fuelling), installer backup such as 100% being able to fix any LPG problem 1st time, possible future upgrades from the installer such as extra tanks, maybe a pump to pump gas from red bottles, etc.
