- Billingham
- Karl
- E50
- North East
I have just finished sending out all of the emails for the tickets. Please check your spam folder if you cannot see them in your main inbox. If you still cannot find them, please let me know. Also, it is important (to make sure I've not fucked up) that you CHECK YOUR TICKET NUMBERS against the list below!
YOU MUST PRINT YOUR TICKET AND PROVIDE IT TO SECURITY AT THE GATES OF THE SHOW - FAILURE TO DISPLAY A TICKET WILL RESULT IN NO ENTRY BEING PERMITTED
This is important as EACH TICKET CAN ONLY BE USED ONCE TO GAIN ENTRY. So if I've mixed up anywhere, someone is going to end up stuck. I'd rather know NOW that everything is OK before the day of the show, when there's a lot going on and I'll be running around like a headless chicken!
If the attachment in your email is NOT YOUR USERNAME then you have the WRONG TICKETS. Please check that the PDF attached to the email has your username and that the ticket numbers in the PDF correspond to the numbers against your name below.
Your Ticket Number is on the top right of the ticket, and will be "AHETJU / TICKET NUMBER"
- @Karl & @Pippa - 1 & 2 - CONFIRMED
- @Pixelpoker - 3 - CONFIRMED
- @Karlos - 4 - CONFIRMED
- @dognero - 5 & 6 - CONFIRMED
- @Revo - 7 & 8 - CONFIRMED
- @Wolop - 9
- @BMR - 10 & 11
- @Shez - 12
- @KevT - 13 & 14
- @Ian Jones - 15
- @Cliff goodwin - 16 & 17 - CONFIRMED
- @Dai & Sally - 18 & 19
- @Elementian & @Lisa-Marie - 20 & 21
- @Chris davies - 22
- @RobP - 23 & 24 - CONFIRMED
- @headless - 25 - CONFIRMED
- @Simjoh - 26, 27 28 - CONFIRMED
- @Mr G - 29 - CONFIRMED
- @ALLUN ROBINS - 30
- @Lize - 31 - CONFIRMED
- @Elgrand Cymru - 32 & 33
- @Darryl - 34
- @Michael6457 - 35 & 36
- @KnightRider - 37 & 38 - CONFIRMED
- @stevemen - 39 & 40
- @Malcwit - 42 & 43 - CONFIRMED
