- Birmingham
- michael
- Midlands
I will be leaving round 1030hrs so arriving round 1400hrs but can't get pod until 1600hrs see you all later today have a safe journey
Not one of my conversions...
Very sorry to hear about this though.
A few points...
Why did you have the tank fitted inside on an Elgrand anyway? The external spare wheel position is the obvious best position for an LPG tank on an E51 Elgrand.
If the installer fitted the tank internally they should have fitted 'external venting'. External venting means that all the connecting pipes to the tank that run internally, and the valve on the tank itself, are all covered with a 'gas tight housing' (so a housing around the valve/s on the tank and overpipes around all the gas pipes) which only has an opening to outside the vehicle... so that in case of a gas leak no gas enters the vehicle anyway... instead of gas entering the vehicle any gas from any leak on any pipe or from the valve (even if the pressure relief valve opens) all goes outside instead of any gas entering the vehicle. Even fillers that are fitted on (say) vehicle wings (where the inside of the wing is inside the vehicle) should be externally vented... so behind the filler there should be a rubber boot and from the rubber boot a wide over-pipe runs to a bulkhead fitting through the floor, the gas pipe connecting to the filler all runs inside the over-pipe and the rubber boot.
Even if external venting wasn't fitted (and I have run my own vehicles with 'unusual' LPG tanks that didn't feature/allow external venting with no concerns), LPG is none toxic... You can breathe LPG and it won't hurt you. The only thing about breathing LPG that can hurt you is that the presence of LPG means less presence of air, so you can be asphyxiated by LPG but you strictly speaking you can't be poisoned by it. The 'stinking agent' in LPG is toxic but only in very high quantities (like drinking it neat - not that you would lol), the 'after smell' that might linger on something (or in a vehicle) after an LPG leak might not smell very nice but it will be in such small concentrations that it won't be toxic. Why was the car written off? I doubt much truth in 'bio contamination'. Put it this way, I would gladly buy your car, wait until the smell subsided then run it as my daily driver.... But probably fit a different LPG tank on it ;-) And then (come to think of it) probably fettle the LPG system components in the engine bay too.
If I was there when this happened I'd have been able to save your car and the forecourt wouldn't have been closed.
Most camping gas bottles feature an over pressure relief valve and are carried inside vehicles... they don't have external venting but they are considered safe. An autogas tank that isn't fitted with external venting (as really it should be) is just as safe as carrying a camping gas bottle... but autogas tanks are usually safer than camping gas bottles and not just because of the external venting.
Is Lisa on siteOnly two of us here at the moment
There’s a coop but might be closed by the time you get there… I’d suggest going to Asda in Merthyr before If you’re desperate or can get it in town maybe tomorrowIs there a shop near by for a house bulb and conditioner as I'm a hour in and not spinning round lol
Edit got conditioner now just a bulb
I will prob arriving at same time tomorrow.Van is loaded and ready. Only an hour down the road so will be leaving at about 12.30ish to be with you for 1.30 tomorrow afternoon.
Random question, is any1 else a eurovision fan?
Hoping to get a stream for it Saturday night
Fixing our own food but we have drinks and muffins/ crisps for everyone hahaGonna go shopping in the morning. As long as I got beer I'm happy. Not sure the wife will see it thar way though....
