It's a 2002 with about 130000km on the clock.
But... You've got to bare in mind the use it was getting at the time. It was pulling a lot of weight up a steep hill at motorway speeds, if it hadn't been for that I doubt it would have broken at that time (though it might have still broken at some time).
Ours frequently hits the highway. One reason I was concerned about not having decored those rear cats. Tried to tell my wife about why it needed to be done but talking stuff like this to her is pointless. I removed the cats and showed her the short one and then she understood my concern better.
When I say a lot of weight, I mean itself plus about another 2.5tonnes...
Sorry to hear of your problems , I will be coming down next weekend for a conversion so will chat to you at end of week .🙁😎👍
We spoke recently and arranged Monday morning unless we speak again before then? :-)
Just wanted to check, is it preferable to decore/remove the rear cats as opposed to the forward cats? Is that because of function and emissions/ease of accessibility/concealability of work done? Should be getting my Elgrand very soon and this is in the top three of jobs I intend to do/have done, and I wanted to understand not just the reason for the potential failure, but the choice of how to mitigate it.
On reading this back I've realised what a difficult-to-read post I've written.
It’s the rear cats that are recommended to be removed, because any debris from failing front cats can block the rear cats, causing terminal engine failure.
I offer a de-catting service on an exchange basis, based in Hampshire UK. If you are too far away, I now offer a mail order option, de-catting and refurbishing and VHT protecting your own rear cats.
Here they are, before and after...
I'm in Exeter so a few hours drive away but I'll bear that in mind for when I've taken delivery, thanks for the info. With the tidy up and paint the refurbed exhaust sections look brand new!
LIST OF AFFECTED MEMBERS
The problem
damage to the engine.
The PRIMARY cats are the problem. Through use, after heating up and cooling down, they start to deteriorate. This happens with ANY catalytic converter when they reach the end of the their life. As the PRIMARY cats starts to break down and fall apart, the debris is pushed back through the exhaust. At this point, they come into contact with the SECONDARY cats, which creates a blockage.
There are 2 main options.
1/ DECORE the SECONDARY CATS. This is a simple process. You remove the secondary cats, cut an opening in the top, smash the internals out, weld the opening shut again and re-fit them. This removes the point at which the debris from the PRIMARY cats will get stuck creating a blockage. The debris is just pushed out the back of the exhaust.
2/ Remove the SECONDARY CATS. Same principle as option 1, but you remove the cats altogether and replace with a straight through pipe. This is more costly than option 1, BUT what it means is that when it comes to MOT time, you still have the cats to fit to the vehicle if there are ever any issues.
But what about.......?
Is this legal?
Why does this need doing?
As a a newbie to all that is Elgrand this info is invaluable, thanks.
Does anybody recommend an exhaust upgrade that doesn’t have the rear cats ?
As a new to be Elgrand owner having the secondary cats, removed or decatted will have to be a priority job, thanks for this info!
Be custom job fella
There's not a straight replacement...any exhaust shop can make you one up....
@Lpgc I’ve seen inside a engine that had cat probs , to be honest engine was totally goosed , be cheaper and easier to get replacement
Hubby is going to decore the cats this weekend. I just want to know, will the van be noisy after this? Will it sound like a tractor?
When we did our previous bmw it sounded like a tractor and do not want a noisy car.
Don't worry, you only need to do the rear cats and It won't sound like a tractor afterwards :-)
I have had straight pipes fitted to mine
if you floor it and have windows open there is a very low burble but on general cruise no noise whatsoever...one thing I want to change about the Elgrand, I want a little noise...perhaps a flap somewhere...
love a good flap I do :cool:
