- Cheshireville
- Peter
- North West
I rebuilt my old starter and found the two motor bearings to be fine, the brushes x4 were half worn and the contacts on the motor were black - I cleaned all contacts with wire wool.
I think the solenoid was the fault, as the plunger would not fire every time when hooked it to a battery.
After opening and cleaning the plunger and bore with wire wool then lubricating - It fired every time.
So I replaced the brush collar in the starter with a new one and cleaned everything and now I have a good genuine Nissan starter to put in my ‘just in case drawer’.
Some of my photos disappeared- but you get the idea.
Edited to add…
In several places the internal parts were stamped MITSUBISHI as is the id sticker - a bit odd.
Edited to add…
