Hi All
I have 2008 2.5 Elgrand bought recently with problem Idle. Engine idles and hunting between 1500 - 2200 RPM. I thought this will just need an Idle relearn using the NDS11 app.
I tried the idle relearn using the app with all conditions satisfied i.e engine warm, electrical loads off, steering straight etc. It keeps saying ECU Busy then it times out and says IVAF failed. I have checked for vacuum leaks, cleaned throttle body etc but no luck.
I have heard that if the idle to start off with is too high above 1200 RPM or hunting badly then idle relearn with the NDS11 app will not work. On some websites it suggest disconnecting one or two injectors to bring the idle down before doing the Idle relearn with the app might be the solution to get it to work.
Anyone who has heard or tried this procedure or anyone with any ideas of solving this problem
Help is much appreciated.
